Author Topic: Fault code 10,3,4,10 - 2ltr V reg  (Read 1000 times)
wayneywoo
  • Hemel Hempstead
« on: 16 March 2008, 14:42:29 »
Hi all,
Can anyone confirm that the above fault code is the camshaft sensor, what sort of job it is and how much a replacement sensor will be?
I've done the paperclip test and I get repeated over and over 10 slight pause 3 slight pause 4 slight pause 10 longer pause then it repeats.
Thanks guys!
edit: Sorry, forgot to say it seems the engine light comes on when the car is cold and the fault I get is a rev limit at around 4500rpm and very sluggish to pull away.  Seems more like a 1.4 than a 2.0ltr  Does this all sound familiar to anyone?
« Last Edit: 16 March 2008, 14:47:25 by wayneywoo »
    • 530D M Sport, 330i Coupe
Re: Fault code 10,3,4,10 - 2ltr V reg
« Reply #1 on: 16 March 2008, 14:57:42 »
Cam Sensor fault  :y
Easy to replace, lift the wiring tray off, release the aux belt, release the cambelt cover and remove the bolt between the cam sprockets holding the sensor in place.
Remove the Ecotec strip off the top of the engine and pull the sensor up using the cable IIRC.
Some pictures here:-
www.doc-scorpion.narod.ru/art17.htm
« Last Edit: 16 March 2008, 15:09:19 by VXL_V6 »
« Reply #2 on: 16 March 2008, 16:41:57 »
thats a 0340 which is cam sensor as suggestted.
westy
  • irish west coast
« Reply #3 on: 16 March 2008, 17:09:53 »
same as symptoms as  mine, read my codes with mates tech 2 and it said cam sensor . buy a genuine vaux or opel one i didnt and know i have to change it again  :(
