Author Topic: Heater matrix....  (Read 2390 times)
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
Heater matrix....
« on: 09 March 2008, 20:34:47 »
Go on then give me a laugh... how long to get at it and any tips ?
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Heater matrix....
« Reply #1 on: 09 March 2008, 20:42:47 »
Why is it leaking into the car?
Debs.
« Reply #2 on: 09 March 2008, 20:44:08 »
Leaking or blocked?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #3 on: 09 March 2008, 20:45:37 »
If it is bloked no need to remove it, take off the two heater pipes that go through the bulkhead and stick your garden hose on one then the other flushing it out :y
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #4 on: 09 March 2008, 20:45:49 »
Yeah, but only when I drive like a loon, other wise it's fine,
Just drops a little into the drivers side footwell
« Reply #5 on: 09 March 2008, 20:47:16 »
whole day job even in opel service..
lots of stuff to take out..if all the nuts and screws are not moved you
will break some plastic parts which will make noise after..
and theres a gray plastic pipe behind the steering which hides a screw..
so  dont bend or force the dash ..You must completely
move it..Also as I watch them they disconnect the battery and take
the airbags out..(at least the passenger side is must I think)
the box around the hand brake also goes out ..Some screws are
hidden also in the vents and lightswitch area..
Sorry for bad explanation :-[
« Last Edit: 09 March 2008, 21:00:33 by cem_devecioglu »
« Reply #6 on: 09 March 2008, 20:48:11 »
will increase after !
amba
  • Medway towns
    • German V6
« Reply #7 on: 09 March 2008, 20:54:36 »
Last year I was quoted £460=00 to remove and replace heater matrix,but that did include price of heater but unsure if it was for original GM unit as local vauxhall specalist garage(if there is one !!)but was warned that may need to get some extra parts once they got it to pieces as some bits would almost certainly break..not sure waht they really ment by that as never got it done
« Reply #8 on: 09 March 2008, 21:09:09 »
if they know the job nothing will be broken..
problem is the movement is in a limited space and needs help..
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #9 on: 14 March 2008, 13:56:32 »
Dont supose any one has any pics of where the heater matrix lives do they ?
« Reply #10 on: 14 March 2008, 14:07:54 »
approx 20 cms down the ash tray(inside)
and horizontally 15-20 behind..
« Last Edit: 14 March 2008, 14:09:00 by cem_devecioglu »
« Reply #11 on: 14 March 2008, 14:23:03 »
Given the symptoms it sounds like it might just want the rubber seals changing which is much easier.
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #12 on: 14 March 2008, 14:27:20 »
Ah my ne best friend !
Tell me more !
BTW it's not dropped any thing in the last 48 hours till I gave it some beans last night :)
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #13 on: 16 March 2008, 19:37:03 »
Bumpage
Any one got any more info on these ?
