Author Topic: car running hot and overheating at fast speeds  (Read 1521 times)
firemansam1066
  • Nottingham
« on: 13 March 2008, 20:55:05 »
hello folks, as the title really, my cars temperature guage sits at about 90, goes up slightly at times through normal use, but as i speed up it goes up, almost instantly.
say at 80-90 it is normal, well if its normal, but over 100 it starts to go over, at 130 the guage is off the scale and the light comes on, like i say it happens almost instantly.
i've read all the posts and all i've done is confused myself.
thanks folks. :-/
Re: car running hot and overheating at fast speeds
« Reply #1 on: 13 March 2008, 21:07:21 »
Start by flushing coolant, then looking for poor circulation.
Mike Collins
  • North of Bristol
« Reply #2 on: 13 March 2008, 22:23:35 »
What's its history? Previous oil cooler failure?
When my last 2.5 did that it was a blocked radiator core, had to adjust cruising speed according to indicated temperature.
That was supposed to be a relatively new radiator after accident repair, no oil cooler failure.
Tried all kind of fixes until flow check and recore cleared it.
Be wary of looking at the flow with a hose in one side of the radiator, the auxiliary pump bypasses the core and makes it look good.
« Reply #3 on: 14 March 2008, 12:02:34 »
Thermostat!!
try checking by immersing in boiling water!
« Last Edit: 14 March 2008, 12:03:56 by cem_devecioglu »
106rallye
  • Glasgow
« Reply #4 on: 14 March 2008, 12:35:51 »
It definetely sounds like a coolant problem, check the basics like does the radiator/pipes get hot? is hot air always avaliable from the heaters? is it losing any water? is there anything blocking the radiator? ie plastic bag, leaves etc.
I wouldnt imagine it would be the thermostat because any ive seen fail before generally makes them run hot always and not just at speeds.
sideways is the way forward!
firemansam1066
  • Nottingham
« Reply #5 on: 16 March 2008, 20:27:30 »
i thought the thermostat would have kept the heater temperature cold but the blowers are hot in normal time. no obvious coolant loss, well i've no need to top it up anyway, nothing seemingly blocking the radiator, the rear fan spins, at temperature but the front twin fans never operate. all the radiator pipes seem hot, all i'm getting is confused.
thanks
jay
« Reply #6 on: 16 March 2008, 20:31:27 »
Depends whether it's failed open or closed.
« Reply #7 on: 16 March 2008, 20:43:57 »
mine was heating only at high rpms and climbing the mountains..
the friend mechanics tell me to jet-wash my radiator (from mud) and added that it cant be thermostat ;D
turned out to be thermostat.. ;D
after the replacement they believe me >:(
Page created in 0.041 seconds with 17 queries.
