2003 2.6 Elite Question?
Started by Drewomega, 12 March 2008, 12:49:23
Drewomega
 8-)Hi! I have picked up my 2003 2.6 Elite after my 3.0 Elite drowned. I do not like the interior as much as my 1998 Elite, too plasticky! however, it is immaculate. There is only one niggle, the "radio safe" keeps flashing up. I have tried entering the codes shown in the manual but it will not have it. I have fitted a new battery as well but still the radio comes on ok after reconnecting, only flashing "radio safe" after every couple of seconds or so. Has anybody got any ideas on this? I would appreciate it. Thanks.
I'm always last in the office in the morning but I make up for it by leaving first.
sounds like the radio has been replaced from the orginal factory fit.
What headunit is fitted?
Drewomega
Quotesounds like the radio has been replaced from the orginal factory fit.
Its the Siemens NCDC 2013 unit. looks original!
Colour or Mono display?
Usually a pairing problem between Headunit on screen on these units.
I was refering to maybe a replacement of the standard factory fit, and someone has not updated the code in the book.
It may have gone faulty and been replaced with an identical unit, but this would have a different code.
As mentioned above, is your display colour or mono?
edwardmickey
If it's beeping 'radio safe' - it needs tech2 with the car pass.
Drewomega
QuoteColour or Mono display?
Colour display. As far as I know everything is original.
Drewomega
I have just had a look at the very comprehensive service/repair history that the previous owner has left me and there is no mention of radio/display unit being changed.
Sounds like it needs a chat with Tech 2, Do you have the car pass and whereabouts are you?
Drewomega
QuoteSounds like it needs a chat with Tech 2, Do you have the car pass and whereabouts are you?
Yes! I have the car pass and I am near Inverness!! I bet nobody with a Tech2 is near here!  :-[
Drewomega
How much do Vauxhall charge for a Tech2 session? Thanks
bobbertbear
i have the sykes pickavant reader if its any good,am other side of invergordon ;)
Drewomega
Quotei have the sykes pickavant reader if its any good,am other side of invergordon ;)
Hi Rob! Tried to email you but seems to be wrong address!
Drewomega
Re: Tech2 devices is this thing any good or does it just read codes? Thanks
http://www.ajdirect.co.uk/tech2-usb-diagnostics-kit-for-vauxhall-opel-p-197.html
NCDC series radios do not have codes ;)
