how can i get more power
Started by topdogkelv, 17 March 2008, 18:39:52
topdogkelv
hi kind people im at a lose end im trying everything to get more power out of my mv6 so far i have full S/S exhaust K&N induction kit smothed and polished throtle bodies blocked off egr valve to stop hot air getting back into engine and plans vey soon for a ecu remap just dont konw where to turn could go for a supercharger but not sure of costs and who to turn to also is there any websites out there that i could look at for ths sort of thing and for modifying my face lift omega as ebay dosent cut it
Albatross
You don't say what your starting point (engine size) is
EGR valve will close on full throttle anyway. Make sure you're getting the most from what you've got. Does the induction air suck only hot air from in front of the radiator or is it able to take warm air from the engine bay?
Exhaust manifolds are reckoned to be a weak point and looking at the factory ones that's fair comment. Problem is, although one or two sources have tubular manifolds for the V6 they are for LHD Omegas and would likely not fit a RHD car.
The frank answer is, to do much more is going to start getting very expensive because there aren't too many off-the-shelf solutions available.
trebor
I'm in the same process....just ordered the smoothed/polished throttle plates, blocked off egr and removed hot water pipes from throttles too. Added an induction kit too.
Haven't done exhaust, but when I do will be looking for cat bypass pipes.  Also looking for some inlet cams to replace the existing exhaust ones.
Then might look into a unichip or similar.
Try a cooler thermostat from courtney sport too.
Markie
#4
Your issue is threefold:
1. lack of support for such a car in terms of well developed add ons.
2. Those that are out there are way over priced, unproven or just gimmicks
3. Not knowing your engine or BHP, but the v6 really needs some extensive work to take much more - ie supercharged power...
topdogkelv
oh sorry its a 3.0l MV6 manual facelift
Markie
Quoteoh sorry its a 3.0l MV6 manual facelift
So your running 207 ish if its fully fit as standard....that engine wont really survive serious power increases, assuming you can find any  :-/
markey mark
well my mv6 3.0 is running chip carbon air filter full stainless decatted sounds wicked and quite happy with power have looked into supercharging but kits cost £3500 and can only run half a bar  ::)
QuoteYour issue is threefold:
I recall discussion that the cooling around the rear cylinders isn't up to the job above 250 BHP too.
Compression is quite high as standard so if you want to get a significant increase by forced induction that will need to be reduced.
TBH, if the car is significantly below your aspirations in standard form it might be easier to look at an engine swap for something with more tuning support.
topdogkelv
so basicly im screwed lol oh dear well thanks boys for the help suppose il never reach the 300bhp point il have to live with it and just upgrade everything on it as i dont want to let her go as shes a nice car and still upsets the boy racers that try it on with me
Markie
Quoteso basicly im screwed lol oh dear well thanks boys for the help suppose il never reach the 300bhp point il have to live with it and just upgrade everything on it as i dont want to let her go as shes a nice car and still upsets the boy racers that try it on with me
theres only one way i think you will break 300bhp in thaty omega shell.......
And its expensive, rare and hard work.
Step forward Omegatoy  ;D
markey mark
loutus carlton engine transplant matey !! or a big shot of nos !!! ;D ;D
topdogkelv
Albatross
Or you could try a VX Monaro Wortec supercharged engine. Over 600bhp.
That might do it.
markey mark
Quotewhere can i get one lol
loutus carlton engines are like rocking horse poo matey !! :-?
