Author Topic: Welding a cat?  (Read 1398 times)
Humpy
  • Tunbridge Wells, Kent
Welding a cat?
« on: 18 March 2008, 14:19:14 »
Chaps,
After having four fat boys (me being one of them!) in the meega at the weekend I bounced the front end down a bit hard off of a speed bump and since then the exhaust has been blowing >:( Anyway, I've had a quick look and theirs a tiny hole on the left cat, where the output pipe is welded to the cat body. I guess it flexed a bit and split the weld.
My question is this, can you weld cats? The body of the cat and the o/p pipe seem quite robust and weldable as opposed to the standard thin exhaust so I would think it's doable, but I wouldn't want to mess the cat up! And if you can is there any precautions to take with a car full of electronic gizmos? I guess removing the battery would be a good start but anything else?
Ta, Humpy
markey mark
  • SLady bitshorpe north lincs
Re: Welding a cat?
« Reply #1 on: 18 March 2008, 15:20:06 »
yes mate you can weld it just disconect yor battery first !! :y
Humpy
Re: Welding a cat?
« Reply #2 on: 18 March 2008, 16:08:03 »
That's handy! Thanks Mark, saves replacing/removing the cat! :)
Humpy
« Last Edit: 18 March 2008, 16:15:35 by Humpy »
Mike Collins
  • North of Bristol
Re: Welding a cat?
« Reply #3 on: 18 March 2008, 21:35:49 »
I may be barking up the wrong tree here, but I've never understood how disconnecting the battery will stop high voltage spikes and RFI damaging the electronics.
That was the main reason I used pop rivets to repair the door checkstrap.
Fire prevention if a cable gets burnt yes.
Surely a low  impedance ie battery, would short most of the spikes to ground. Join the battery leads together after removing it?
Expert opinions invited.
markey mark
Re: Welding a cat?
« Reply #4 on: 18 March 2008, 21:38:07 »
dont know fella was always taught to disconect battery whenever you weld on a car !! ::)
rickyboy
  • Glasgow
Re: Welding a cat?
« Reply #5 on: 18 March 2008, 21:46:57 »
You disconnect the battery because the welding arc will fry your alternator and it does work.
« Last Edit: 18 March 2008, 21:48:01 by rickyboy »
Page created in 0.382 seconds with 16 queries.
