Engine management light
Started by denerinian, 24 January 2008, 22:47:17
denerinian
Hi all
Just onto my second Omega now - a 2001 2.2 CDX - and have come across this great forum
All going Ok except (!) engine management light (spanner one) comes on periodically ( will go out on engine restart ) - had local garage do me quick favour and read the fault code - told me it was throttle position sensor plus lean mixture ( said 2 were linked) reset it but has come on again - does'nt seem to have adverse affect on car - Any ideas if this is simple fix ???
Where they able to give a live data test on it.  Were the faults they detetced Present or Not Present?
denerinian
Thanks for reply but sorry all i know is what they told me - also been told by someone else that this light is only 'service light'???  :-?
QuoteThanks for reply but sorry all i know is what they told me - also been told by someone else that this light is only 'service light'???  :-?
'dangle berries', Omega does not have a Service/SVS/etc type light. Its a fault.
Is it still happening? If so, tell garage to do it properly, or if they are too stupid to use diag equip, use a different garage.
denerinian
Thought as much - I'm getting OBDII code reader so can check fault codes - i'll go from there - I'll see if i get same code result as before i.e TPS - is this common fault ??
QuoteThought as much - I'm getting OBDII code reader so can check fault codes - i'll go from there - I'll see if i get same code result as before i.e TPS - is this common fault ??
If you can get a tool that can do live data readings, that is more useful than a simple code reader
alexandjen
Keep us posted on your progress and what fault codes are present  :y
Trade club card holder
Code scanner available
Cardiff is not THAT far from one of the two members with a "proper" TechII .. might be worth paying one a visit ??
That way you get
1. someone who actually knows how to read the data correctly
2. an ACCURATE description of the problem
3. probably a list of the exact steps needed to fix it !!
Kieran
I To have the engine managment light that has come on with no actual effect on the cars performance.
On friday the car is going in to have it checked out so will let you know what they say.
The light has been on and off for about three months now and have tried to locate the problem using one of the handheld diagnostics but no faults come up.Time  i think to get it checked . ::)
denerinian
Problem sorted - was the old throttle body / breathers dirty - cleaned up and no more light !!
alexandjen
Nice to hear the problem is solved .. well done .. :)
