crank shaft sensor
Started by psnimv6, 20 March 2008, 15:40:32
psnimv6
hello as some of you might of seen i am having running problems with my 2001 3.0 mv6 anyway i replaced my crank shaft sensor with one of ebay vx dealer but it is siemens not bosch and the car seems to still be not happy although it is running fine today after replacing coil pack but i have just noticed that the part number is for late model 2.5 omegas will that make any difference as it fits and looks the same and the car is going ok but it is still storing fault code 19 could it be because the sensor (part number 90492061) and it should be (90540743) is not suitable or is will it work ok with my 3.0 engine
Quotehello as some of you might of seen i am having running problems with my 2001 3.0 mv6 anyway i replaced my crank shaft sensor with one of ebay vx dealer but it is siemens not bosch and the car seems to still be not happy although it is running fine today after replacing coil pack but i have just noticed that the part number is for late model 2.5 omegas will that make any difference as it fits and looks the same and the car is going ok but it is still storing fault code 19 could it be because the sensor (part number 90492061) and it should be (90540743) is not suitable or is will it work ok with my 3.0 engine
It should be fine.
So the DIS pack change sorted the poor running then?
