Metal relief on floor.
Started by Olympia5776, 20 March 2008, 09:50:51
Olympia5776
I have searched through the old posts for the info that was posted re relieving the metal around the floor area adjacent to the inner wheel arch to stop creaking . Can Mark DTM or anyone else post it up again.
I find that when I'm turning slowly onto my drive there is a gentle creak at the back as if the shell is distorting  :o I've adjusted the rear estate door rubber stops and sprayed 3 in 1 all around the trim pieces but it's still there.
Sounds a bit OCD  perhaps but I hate creaks or rattles in the car. >:(
Don
Richard A
Use "silicon" spray on all the door surround rubber seals and also "pack grease" in all the door catches, it is also worth spraying the silicon over all the rubber suspension joints and mountings. Seals tend to dry out over time then start to creak.  :y :y
regards
richard
richard a
Ralph
http://www.omegaowners.com/forum/YaBB.pl?num=1204578715
This might be what you are looking for, I hope to try the fix this weekend
Olympia5776
I literally just found it and was about to post it up when here you are.  :y
Thanks for the reply ,I hope it didn't take you as long as it took me to find it. ::)
I'll be doing it too , let us know if it works for you.
Cheers
Don
Richard A
I never fail but be amazed !!!!!
regards
richard
p.s. still use some "silicon spray"
richard a
