2.0 Ecotec Diss Pack and Plugs question.
Started by zirk, 20 March 2008, 17:57:31
zirk
Am I right in assuming that the Megy 2.0 eco Diss Pak and Plugs are the same as in the 2.0 eco Vectra?
Also can someone confirm that the plugs should run cooler (1 grade down) if these engines are run on LPG?
Cant comment on the LPG requiremenst but, the DIS pack and leads are as per the vectra/astra yes.
zirk
Thanks Mark.
Anyone else on the LPG thingy?
rickyboy
Hi, I posted a similar question about spark plugs and lpg a while ago, here's some suggestions.  General consensus is to use ngk's.
http://www.omegaowners.com/forum/YaBB.pl?num=1205404821/7#7
