Author Topic: pain to start  (Read 1036 times)
kris9128
pain to start
« on: 20 March 2008, 20:43:37 »
only started today. engine cranks as normal but refuses to start. after a few mins of cranking, it pops and farts a few times then starts. once it starts it runs as normal and will start fine. problem only occurs when car is stood for a few hrs. any help would be greatly appreciated. its as if the fuel is draining back to the tank and has to be pulled thru again. i could be wrong tho.
Matchless
  • Nottingham
    • A white van
Re: pain to start
« Reply #1 on: 20 March 2008, 20:59:44 »
Do the 'paper clip' check to look for a code 19...crank sensor.
Also try holding the throttle to the floor while cranking, if it starts immediately like this then you have a weeping injector which is dribbling fuel when engine is stopped and the resulting mixture is too rich to fire on the next start-up.
kris9128
Re: pain to start
« Reply #2 on: 20 March 2008, 21:05:42 »
what is paper clip test. how do i do it.
hotel21
  • The Kingdom of Fife
Re: pain to start
« Reply #3 on: 20 March 2008, 21:08:06 »
http://www.omegaowners.com/forum/YaBB.pl?num=1152601768
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Loads of similar FAQ type things listed in the appropriate sections....   :y
