Author Topic: advice please guys  (Read 3668 times)
Marie
    • 2ltr LPG Estate
advice please guys
« on: 07 March 2008, 21:02:17 »
right i think i have potentailly 2 problems which i dont know whether they are related or not. thats for you all to decide........
1. have noticed that the temp guage does not rise above 90 unless stuck in traffic and takes a while a few miles to get there.
i have only done short runs with her so i will keep an eye on it when i take her to pick the hubby up tomorrow in london. (its about an hour away down the motorway).
2. burning oil smell. outside car after a run. its not a massive smell ( i still have a cold) but smells worse when i stick my head in the passengers side wheel arch.
have looked inside the engine and i cant see any leaks. there are no spot marks on the ground from where she has been parked. no visible oil level change. the only thing i have done recently is change the oil from15w to 10w. under the advice of James.
Are these to problems related ??? thats if the temp guage is a problem (will confirm this tomorrow)
what should i do???
markey mark
  • SLady bitshorpe north lincs
Re: advice please guys
« Reply #1 on: 07 March 2008, 21:04:50 »
number 1 could be stuck thermostat
number 2 cam cover gasket dripping on exhaust manifold  :y
« Reply #2 on: 07 March 2008, 21:15:18 »
the 4pots rarely go above 90.
My 2.2 has never gone above 85 in months.
Only time i have got it to 90 is when i have just been blasting it, and come to a dead stop for 5 mins, in really hot summer weather.
Lot of space in the engine bay with the 4 pots, so they stay quite cool  :)
« Reply #3 on: 07 March 2008, 21:18:00 »
Are you talking MPH tunnie?
Thought this thread was about temperature  ;D
Marie
    • 2ltr LPG Estate
« Reply #4 on: 07 March 2008, 21:19:19 »
phew and here i was thinkin i was going to have to part with some more cash and spend more time fixing the motor.
« Reply #5 on: 08 March 2008, 00:14:09 »
At the risk of sounding boring, as I am always saying this, FACELIFT CARS HAVE DIFFERENT SCALES ON GAUGE!!!
Marie - your does sound a little low, i'd expect 92 - 94 cruising...
Marie
    • 2ltr LPG Estate
« Reply #6 on: 08 March 2008, 08:08:16 »
well we will see what i get today when shes crusing down the motorway.  ;)
theolodian
  • I need a new avatar.
« Reply #7 on: 08 March 2008, 08:19:48 »
Only time i have got it to 90 is when i have been blasting it :)
Sounds about right.  ;D ;D
My V6 goes 100+ easily.  :P
Danny
  • Wigan, Greater Manchester
« Reply #8 on: 08 March 2008, 10:28:24 »
I shall also confirm my 2.0 could sit at 85-90 on a steady cruise
and for the burning oil, check cam cover gaskets leaking oil onto exhaust manifold as said
« Reply #9 on: 08 March 2008, 11:30:53 »
85 is standard operating temp for 2.2... so should imagine its same for the 2.0. Facelift or pre-facelift
Marie
    • 2ltr LPG Estate
« Reply #10 on: 08 March 2008, 13:37:13 »
I shall also confirm my 2.0 could sit at 85-90 on a steady cruiseand for the burning oil, check cam cover gaskets leaking oil onto exhaust manifold as said
thats where she sat on the motorway doing 75 /80mph.
when we were within town stoping and starting cos of light she crept up to 92 max 95. so see ok.
and as for the oil burning smell couldnt smell it when i got back today but will keep a close eye on it.
« Reply #11 on: 08 March 2008, 13:59:27 »
Marie - what are the markings on your gauge, I'm guessing 90C and 100C, in which case, 85-90C is too cold.
« Reply #12 on: 08 March 2008, 14:00:37 »
Your gauge markings will be 80 and 100C. Prefacelift will be 90 and 100C
Marie
    • 2ltr LPG Estate
« Reply #13 on: 08 March 2008, 14:01:43 »
ok (split opionions on here) so if its too cold whats up with it then???????????????
she is running fine. no werid noises.
« Last Edit: 08 March 2008, 14:02:51 by marie »
« Reply #14 on: 08 March 2008, 14:06:08 »
Running cold is most likely the stat, but could be error with gauge, or the temp sensor.
If only you were nearer, we could have a play and see what the engine temp sensor was reading,and compare to the gauge temp sensor raw reading  :'(
