Author Topic: cream in the oil filler cap  (Read 2192 times)
Bacon Butty Man
  • Cleveleys Nr Blackpool
  • now own a Laguna 2
« on: 22 March 2008, 16:44:59 »
just checking my oil and on the filler cap there is some cream colored gunky stuff, Cant be good!
any ideas what it is, PLEASE PLEASE PLEASE dont say its the head gasket,  :'( :'( :'( :'( :'( :'( :'( :'(
There wernt a lot, just a bit, i changed the oil 2 weeks ago, i do have a leak which i think is coming from the oil pressure valve, But i have notice a tidgybit of oil in the spark plug hole, i have been surynging this out. any ideas guys
« Last Edit: 22 March 2008, 16:47:46 by baconbuttyman »
my Rover 75 Club SE
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
Re: cream in the oil filler cap
« Reply #1 on: 22 March 2008, 16:47:56 »
its normal on v6`s on short runs particularly in the cold weather. do you do a lot of stop and starts from cold / short journeys? advice elsewhere on the forum suggests you clean it up as and when you notice it and make sure you take the car out on a longer journey / motorway blast from time to time:
http://www.omegaowners.com/forum/YaBB.pl?num=1205911746
« Last Edit: 22 March 2008, 16:52:20 by ilovemyelite »
PM with your requests.
« Reply #2 on: 22 March 2008, 16:53:20 »
as said above the mayo is normal if car does short journeys,it also sounds like you will need to clean breathers and change cam cover gaskets in the near future ,otherwise the oil wil start damaging plug leads/dis pack :y
humbucker
  • Cambridgeshire
« Reply #3 on: 22 March 2008, 16:55:55 »
all you need re cam cover gasket replacement is here. i love this forum! :
http://www.omegaowners.com/forum/YaBB.pl?num=1152564281
Bacon Butty Man
« Reply #4 on: 22 March 2008, 17:09:47 »
so its not serious :D :D :D :D :D :D :D :D :D :D :D :D
The car does only short journeys, i did clean it up earlier, thanx for the link for the rocker cover gaskets, will study that, cheers
my Rover 75 Club SE
« Reply #5 on: 22 March 2008, 18:39:42 »
remember, breathers likely to be similar, so clean them ;)
IME, Vx oil seems to suffer less than many others, no idea why.
Bacon Butty Man
« Reply #6 on: 22 March 2008, 19:05:44 »
Ok further investigation done, took the oil filler cap off and there is a smell of fuel coming from the oil cap tube, also need filling with water in the cooling system quite regularly, average ever 8 days or so. :-[
my Rover 75 Club SE
Dazzler
  • Haverhill, Suffolk
« Reply #7 on: 22 March 2008, 19:09:43 »
Is there any mayo on the dipstick???
Have you checked the HBV for signs of a waterleak??
Bacon Butty Man
« Reply #8 on: 22 March 2008, 19:11:17 »
Hi
no mayo on the dip stick, i cannot see any leaks, What the HBV
my Rover 75 Club SE
Danny
  • Wigan, Greater Manchester
« Reply #9 on: 22 March 2008, 19:28:37 »
Hi
heater bypass valve
the mayo sounds like a bit of condensation build-up, from the short journeys, give it a motorway run and see how it is afterwards
« Last Edit: 22 March 2008, 19:28:57 by D4NNY »
Bacon Butty Man
« Reply #10 on: 22 March 2008, 19:38:49 »
Hi
heater bypass valve
What would be causing the fuel smell from the oil filler pipe tho??. thats whats worrying me
my Rover 75 Club SE
« Reply #11 on: 22 March 2008, 19:58:51 »
Hi
heater bypass valve
bit of blow by gases?
Bacon Butty Man
« Reply #12 on: 22 March 2008, 20:03:52 »
would a dodgy head gasket cause this or do you think its no real prob, Am gonna clean the breathers tomos.
my Rover 75 Club SE
« Reply #13 on: 22 March 2008, 20:08:35 »
A HG failure would not cause that.
Bacon Butty Man
« Reply #14 on: 22 March 2008, 20:26:07 »
 :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y :y
my Rover 75 Club SE
