Pages: 1 [2] 3  All   Go Down
Author Topic: wont idle  (Read 6696 times)
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: wont idle
« Reply #15 on: 18 March 2008, 20:34:43 »
WD40 is not the lubricant I would use, it's a water dispersant
Try a light machine oil and see if it improves.
Something like 3in1 will help too.
Re: wont idle
« Reply #16 on: 18 March 2008, 23:26:47 »
thanks for the thoughts everyone,there is an icv on ebay at the moment if it is cheap enough i might have it  so i can try swapping to see if that cures the problem,trouble is swmbo now wants to dump it and get something more reliable  >:(.....no chance ;)
« Last Edit: 18 March 2008, 23:27:12 by albitz »
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: wont idle
« Reply #17 on: 19 March 2008, 08:35:54 »
it going to be omething simple - btw carb cleaner  :y
Not sure if i have a spare kicking about - i`ll try and get a chance to check...
Re: wont idle
« Reply #18 on: 19 March 2008, 08:56:07 »
thanks markie :y
philhoward
  • Staffs
  • Love the engines, so put one in something else..
Re: wont idle
« Reply #19 on: 19 March 2008, 21:06:42 »
Mine stalls at junction and about to do the idle breather jet (in the Maintenance section)...might be worth a look..?
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Re: wont idle
« Reply #20 on: 22 March 2008, 14:47:34 »
update;postie just delivered icv (thanks to chris :y) went outside and fitted it,made no difference.the car is hard to start and every time the revs drop to about 600/700 the engine stops.i am now left with the code 19 problem,has the crank sensor really only lasted 10 weeks ? it was a genuine vx item and was routed well away from exhaust manifold :-/ :-/ :-/
Markie
Re: wont idle
« Reply #21 on: 22 March 2008, 16:35:53 »
well code 19 is either crank issue or stored crank issue from before - i reckon you have probably started the car 20 times since fitting the crank eh?
In other words the previous stored code should have gone by now....
Re: wont idle
« Reply #22 on: 22 March 2008, 16:39:21 »
yup,my thoughts exactly ,i just cant believe that its gone wrong so soon. if it has would it give the same symptoms as a dirty icv ? :-/
Markie
Re: wont idle
« Reply #23 on: 22 March 2008, 16:42:07 »
NOT in my experience no - had the code 19 on an old omega estate - it ran and idled fine untill on day it refused to start and replaced sensor...
Re: wont idle
« Reply #24 on: 22 March 2008, 16:49:23 »
i replaced the sensor in jan.because eml was coming on and code 19,it was also a bit difficult to start,but there was no problem with idling.i am surprised that changing icv hasnt helped but having a code 19 is just confusing me further.the only other thing i can  think of is to clean the breathers ,but they have been done within the last year so i wouldnt have thought they are going to be in that bad shape really.i dont really know what to do next tbh,is there any way of testing an icv? :-/ :-/
« Last Edit: 22 March 2008, 16:55:59 by albitz »
Albus Dumbledore
  • Bergen, Norway
Re: wont idle
« Reply #25 on: 22 March 2008, 18:33:50 »
Just a thought. Have you checked the airfilter? Or for cracks in the pipe from airfilter housing to inlet?
Re: wont idle
« Reply #26 on: 22 March 2008, 18:36:21 »
the airfilter is recent but it could be worth a look at the other bits thanks,im starting to feel desperate and confused :'(
Albus Dumbledore
  • Bergen, Norway
Re: wont idle
« Reply #27 on: 22 March 2008, 18:41:34 »
I understand you completely! Hope you find a quick fix :y
Re: wont idle
« Reply #28 on: 22 March 2008, 20:10:40 »
there might be some parts of a fire damaged omega in the for sale section tomorrow :'(
Albus Dumbledore
  • Bergen, Norway
Re: wont idle
« Reply #29 on: 22 March 2008, 20:15:50 »
???? What happened??
Pages: 1 [2] 3  All   Go Up
