Pages: [1] 2 3  All   Go Down
Author Topic: wont idle  (Read 6693 times)
wont idle
« on: 16 March 2008, 23:05:40 »
for the last 2 days my car wont idle,it runs fine above idle speed but dies when i slow down for junctions etc; i have taken the icv off and blasted it with plenty off carb cleaner,but this hasnt improved matters.i have also done a paperclip test and have a code 19 stored,i fitted a new vx crank sensor a couple of months ago and have checked today on how the wiring is routed and it looks fine.i would have thought an old code would have cleared by now ? im feeling a bit confused so any fresh ideas would be appreciated. :-/
Dazzler
  • Haverhill, Suffolk
Re: wont idle
« Reply #1 on: 17 March 2008, 09:08:26 »
did you change the crank sensor and its wiring??
file28
Re: wont idle
« Reply #2 on: 17 March 2008, 09:16:58 »
when i had the sensor changed they changed the wiring as well as it had got warm and became brittle
Re: wont idle
« Reply #3 on: 17 March 2008, 09:25:41 »
yes it comes with the wiring attached,the symptoms suggest to me a dirty icv,which is why i was surprised that there was no improvement after it was cleaned.
keith2.2
  • Lincolnshire
Re: wont idle
« Reply #4 on: 17 March 2008, 09:29:25 »
have you reset the ECU to clear the fault code?
2.2 litre, 210bhp, 910kg stripped honda civic
LPG'd MV6 Omega
Re: wont idle
« Reply #5 on: 17 March 2008, 09:38:39 »
as far as i know they should disappear after approx.20 engine starts,once the fault has been fixed :-/
Re: wont idle
« Reply #6 on: 17 March 2008, 22:02:09 »
anyone got any more ideas ? :-/.......im getting desperate,swmbo wants to use it tomorrow afternoon ,she is getting  >:(
« Last Edit: 17 March 2008, 22:51:16 by albitz »
markey mark
  • SLady bitshorpe north lincs
Re: wont idle
« Reply #7 on: 17 March 2008, 23:39:17 »
did you lube icv after cleaning it out ?? :-?
Re: wont idle
« Reply #8 on: 18 March 2008, 12:16:26 »
yeah,i sprayed some wd40 into it.im now wondering if the icv has packed in but i dont know of any way of testing it .
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: wont idle
« Reply #9 on: 18 March 2008, 12:18:59 »
The only time i have had such a problem ( starting and cutting out immediatley unless revved) was after a breather clean. IACV not properly connected ...
Long shot but even if you can swap out the ICV to eliminate from the problem :-/
Re: wont idle
« Reply #10 on: 18 March 2008, 12:19:59 »
how would i swap out the icv ? :-/
Markie
Re: wont idle
« Reply #11 on: 18 March 2008, 12:22:40 »
change it for a known good - even worth seeing if local scrappy has one.....
Before hand retrace all your steps and check connections.
You need to lube, or fairy liquid the icv around and on the ruibber connection to force it back into the side of the plenum and ensure its snug...
« Last Edit: 18 March 2008, 12:23:30 by Markiec »
Re: wont idle
« Reply #12 on: 18 March 2008, 12:28:45 »
i see what you mean now :-[,that should be worth a try ,cheers for the advice  :y
« Last Edit: 18 March 2008, 12:29:18 by albitz »
Markie
Re: wont idle
« Reply #13 on: 18 March 2008, 12:39:51 »
Alternativlely....pop the icv out just fractionally and see if it makes any difference to your problem...obviously it wont fix it but if your symptoms are exactly the same.... :-/
Mike Collins
  • North of Bristol
Re: wont idle
« Reply #14 on: 18 March 2008, 13:23:46 »
WD40 is not the lubricant I would use, it's a water dispersant
Try a light machine oil and see if it improves.
Pages: [1] 2 3  All   Go Up
