Author Topic: tracking settings  (Read 4818 times)
rad cap
  • manchester
tracking settings
« on: 24 March 2008, 22:03:36 »
fitted a new tre for mot, what is the setting for the tracking, in/out ?.
Re: tracking settings
« Reply #1 on: 24 March 2008, 22:08:02 »
Seem to recall its slightly in.....
.....where had it worn, on the very inner edge, if it has then its camber....not tracking.
rad cap
  • manchester
« Reply #2 on: 24 March 2008, 22:12:02 »
no wear at all, i fitted a new track rod end for mot, put new one on as close as poss but want to check the track, my self and not sum muppet at fick kwick, or garage, i have acces to guages but no settings, thanks
« Reply #3 on: 24 March 2008, 22:13:13 »
Got some good values at work, will post them tomorrow.
rad cap
  • manchester
« Reply #4 on: 24 March 2008, 22:15:50 »
ok that would be great, :y
« Reply #5 on: 24 March 2008, 22:16:28 »
Its worth checking the rear settings as well.
« Reply #6 on: 24 March 2008, 22:17:18 »
BOL says 0o10
rad cap
  • manchester
« Reply #7 on: 24 March 2008, 22:21:09 »
is that in or out.  will check front and rear if i get settings thanks
« Reply #8 on: 24 March 2008, 22:24:20 »
Hmmm....not sure on those, my thinking is toe in because when moving forward the tyre friction will tend to move them towards toward the zero point and you still want a little toe to keep stability....suppose that could be toe out..
« Reply #9 on: 24 March 2008, 22:26:36 »
I was always told that rwd toe in, fwd toe out (or was it other way round?)
« Reply #10 on: 24 March 2008, 22:27:33 »
Which would be correct, but the Haynes toe value is bugger all!
rad cap
  • manchester
« Reply #11 on: 24 March 2008, 22:28:01 »
i would suspect tow in myself, as its rear wheel drive, but setting would be good if you can get them.
« Reply #12 on: 24 March 2008, 22:29:58 »
esp giving the +-10 tolerance!
rad cap
  • manchester
« Reply #13 on: 24 March 2008, 22:35:04 »
will put the gauges on it 1 ngt this week, if work lets up, let u no what i find, thanks for help. we have some gauges at work the boss has them for his rs200 , now thats fast.
« Reply #14 on: 24 March 2008, 22:38:15 »
Theres a blast from the past - my brother did the redesign for that to make it road legal (the original Ford design wasn't road legal), and a heap of work on the 4 wheel drive system used.
