Engine falters at 4000 rpm
Started by HI2DVY, 26 March 2008, 15:44:45
HI2DVY
Strange one this...
My 2.5 V6 has been sitting in the driveway for a few weeks with hardly any use. I took it for a spin today and discovered I can't accelarate past 4000 revs - bit of a problem when trying to overtake! When I get to 4000 rpm the engine seems to jerk violently and the EMS light flashes. It's worse if in sport mode.
I thought it may have been a fuel pick up problem as the tank was quite low but Ive ran a paper clip test and get the following results:-
019 - Incorrect RPM Signal
059 - Intake Manifold Valve 1 Voltage Low
I suspect the 059 may be an old reading from when I changed the head gaskets and forgot to connect the rear multiram connector - but maybe not?
Any ideas what may be causing this?
Dave
some day.....
rickyboy
Crankshaft sensor needs replacing.
HI2DVY
Thanks mate. I'll take a look.
some day.....
Dazzler
As said, code 19 is a faulty crankshaft sensor :y
4k limit is the engine in limp mode because of the fault code ;)
QuoteAs said, code 19 is a faulty crankshaft sensor :y
Thats not limp mode enduced becasue the crank sensor wont initiate any limp mode.....but if the signal is poor then the waveform might start to collapse at higher revs
Dazzler
I bow to your better knowledge Mark :-[
