squeak when i press the clutch pedal
Started by joffy, 26 March 2008, 12:30:01
joffy
my omega makes a squeaking noise whn i press the clutch pedal down...thought it was thrust release bearing at first but had a clutch and bearing fitted and its still happening...have been told now its prob cos crank is moving...engine has 230k on it...just wondering will something like "motor up" or slick 50 cure it....not looking for long term as i just want to sell it!!
jon
facelift cdx,56 plate ford tourneo,71 rover p6 tc,72 rover p6 v8s...yes...i like my cars!!!...and my minibus!!
Bacon Butty Man
have you checked for any trapped mice.   seriously have you tried greasing all the part at the top of the clusch pedal, i had the same prob on my granny, ford said needs new gear box, tried greasing things up and it worked, was the damn spawl n ratchet thingy, i hate rippoff garages like ford. >:(
my Rover 75 Club SE
joffy
the squeak stays on when the pedal is down and definately coming from the engine bay...was a bit gutted when i picked up car from clutch place and it was still making the noise!!!!
Dazzler
Sounds like the thrust bearing which i bet they never changed...... you say that you have had the release bearing replaced though...correct?
me not understandy, whats a clutch pedal ::)
QuoteSounds like the thrust bearing which i bet they never changed...... you say that you have had the release bearing replaced though...correct?
:-/ Are they not one & the same thing?
Dazzler
No, the release bearing is the big one that pushes on the clutch plate, and the thtust bearing is the one that sits in the end of the crankshaft to stabilise the end of the gearbox main shaft. Thats the one that goes on high mileage stuff ;)
Quote.......
Ah! I'm with you now.  ;)
joffy
well i`m lost now....so the gearbox has to come off again????...garage which did the clutch was a friend so trust his judgement...the squeaking did get less after i got the car back so he reckoned i had more than one problem....anyone wanna buy a face lift cdx cheap lol
