Water Leak
Started by DM, 27 March 2008, 14:31:33
DM
Hi all, I have picked a 1998 Omega 3.0 v6 estate. I was giving it a clean out on monday and decided to stick the car through the car wash to keep the kids happy ::)
Since monday I have noticed a leak coming from what appears to be above the passenger side front wheel. The water is coming out as a steady drip. When I first noticed it it seemed to be dirty water but as of wednesday the water is crystal clear. I have tried to see exactly wher the leak is coming from but can not seem to pin point it.
Forgot to add that the coolent lvl has not dropped since I noticed this problem.
Any help or advice would be much appreciated.
Cheers
DM.
It'll be the scuttle drain. Plenty of info on here but briefly, the area under the scuttle where the pollen filter sits has a tendency to fill with water which then leaks through the bulkhead where the heater fan sits.
There's a rubber grommet at the bottom of this area which needs to be unblocked so the water can drain out again.
DM
Wow fast reply, many thanks Kevin. I will do a bit of digging see if I can find out exactly where the rubber grommet is.
Cheers
DM
It's to the left of that chamber as you look at the front of the car (towards the centre of the car). Easiest to drain the water with a Vax or syphon with a length of hose, then find something that'll poke down there (small bottle brush, for example) then flush with a hose. It's much easier with the wipers and scuttle panel off.
Oh, and almost forgot... Welcome to the forum  :y
Dazzler
DM
QuoteOh, and almost forgot... Welcome to the forum  :y
Cheers m8 :) I only stumbeled across this site today, so much useful info on here :y
Update: Managed to find the skuttle drain, successfully drained it. Had trouble squeezing my arm in to feed the piece of wire through but I seemed to have got it now. There was not much gunk/dirt in there but there was a noticable amount of extra water draining as I cleaned the skuttle out.
So far so good, cheers for all the help, very much appreciated :y
Cheers
DM
ians
Oh yes -best to wear wellies when doing that job ;D
QuoteOh yes -best to wear wellies when doing that job ;D
..and employ the services of mr. Tickle.  ;D
Marie
or me ;D ;D ;D ;D ;D ;D
