Author Topic: can you help  (Read 1362 times)
ianboyo
  • Somerset
can you help
« on: 28 March 2008, 19:33:02 »
coming home from work today my meega wasent running on 6 cylinders got a feeling my camshaft senser might be playing up can anyone comfirm this thanks for the help
ian
Marie
    • 2ltr LPG Estate
Re: can you help
« Reply #1 on: 28 March 2008, 19:35:25 »
You might need to expand on this for us......
do you mean lack of power or just slow on the uptake?
ianboyo
  • Somerset
Re: can you help
« Reply #2 on: 28 March 2008, 19:38:52 »
yes a lack of power doesnt sound like its running on all 6?
Albus Dumbledore
  • Bergen, Norway
Re: can you help
« Reply #3 on: 28 March 2008, 19:45:40 »
If your suspicion is correct, a compression test will confirm or not if it's running on all 6. Do you have any other symptoms? missfire?
Re: can you help
« Reply #4 on: 28 March 2008, 19:50:43 »
I would do a paperclip test and see if there are any trouble codes. If not, have a look for oil in your plug wells in case the cam cover gaskets have gone.
It's the crank sensor that normally gives trouble on the V6. That will give you a code 19 with engine running.
Re: can you help
« Reply #5 on: 28 March 2008, 20:00:49 »
I suspect no ECU light on and either oil in the plug wells or a dead DIS pack....
Cant see the crank sensor causing such symptoms....and it certianly is not the cam sensor.
