Author Topic: Cambelt panic  (Read 1732 times)
cbs2
  • East Kilbride
  • Right....Fire Up The Quattro!!!
Cambelt panic
« on: 27 March 2008, 19:21:08 »
Hey guys
Got a problem brewin on the mig
Past 2 mornings, I've had a funny noise from the front of the engine when the cars been started from cold on the choke.
By the looks of it, I've got a pully bearing on its way out.
I've already bought the cambelt kit, aux belt & water pump, But I need a loan of a locking Kit for saturday.
Anybody Glasgow/Central way got one I can borrow??
Didn't think I would need to do it so soon, was waiting for the next meeting, but need the car for monday
Taking part in the 2010 sucata split charity banger run. www.sucatasplit.com
www.boozebrothers2010.co.uk
Ex-mig owner................For now
Re: Cambelt panic
« Reply #1 on: 27 March 2008, 23:38:03 »
Might be worth taking off the aux belt and checking all the ancillaries turn smoothly without significant play. Could just be the aux. belt tensioner or water pump, etc.
If there's any doubt about the cam belt tensioners, however, best to be on the safe side.
Bacon Butty Man
  • Cleveleys Nr Blackpool
  • now own a Laguna 2
Re: Cambelt panic
« Reply #2 on: 28 March 2008, 09:14:36 »
if you cannot get hold of a cam kit, do what the mechanic that did mid did, interlock some spanners where the cam kit would be then cable tie them in place, its a bit crude but it works, i had my doubts when he did it but an hour or so later, cam sorted and runs like a dream. :y
my Rover 75 Club SE
Dazzler
  • Haverhill, Suffolk
Re: Cambelt panic
« Reply #3 on: 28 March 2008, 09:24:13 »
I wouldn't advise it......the kit also sets the crankshaft exactly where it needs to be with ease, and holds everything where it needs to be ;)
Re: Cambelt panic
« Reply #4 on: 28 March 2008, 10:02:23 »
Yes. In addition, whilst the cams can be locked without the locking kit (NEVER use molegrips, however), it's the timing gauge that comes with it that is crucial. The marks on the cam cover backplate are very approximate. You can probably get the engine running using them, but the get the timing right you need the gauge. Remember the timing is continuously variable, so it's not just a matter of being within a tooth on these engines. If I had to set an engine up without the kit, I'd regard it as a stop gap and I'd set it up with the kit at the earliest.
cbs2
  • East Kilbride
Re: Cambelt panic
« Reply #5 on: 28 March 2008, 18:37:53 »
Cheers for the advice guys
I've got a feeling its on the aux belt side, poss the water pump
Started the car tonight & no noise...typical
I'll need to check it out tomorrow after work
Bacon Butty Man
Re: Cambelt panic
« Reply #6 on: 28 March 2008, 20:48:14 »
i put my faith in an expert and hope for the best ;D ;D ;D ;D ;D
my Rover 75 Club SE
