Author Topic: cars back....codes read help..  (Read 3860 times)
Marie
    • 2ltr LPG Estate
« on: 28 March 2008, 15:05:38 »
ok so the paper clip gave me the following flashes:
10 then 5, 10 then 5, 10 then 5
10 then 3 then 4 then 10
then went back round to 10 then 5
so fellas what is it???
Help me plz thank you.
Grumpy
  • Manchester
Re: cars back....codes read help..
« Reply #1 on: 28 March 2008, 15:29:41 »
Hi Marie, I think you need to read the codes again.
Your first line 050505 doesn't make sense to me.
Your second line 0340 = Camshaft Sensor.
The fact that you are getting 10 Flashes which = 0 (zero)
would tend to indicate that you have a Simtec 56.5
which will give you 4 digit codes.
Do the test again, on this basis, looking for 4 digit codes
where 10 flashes = 0 (zero).
I'm told that each code is repeated 3 times before displaying
the next code. I cannot confirm this from personal experience
as I've only ever had 1 fault code that just kept repeating
ad infinitum.
rickyboy
  • Glasgow
« Reply #2 on: 28 March 2008, 15:34:21 »
Yep should get a four digit code, counting 10 flashes as a 0.  They don't repeat three times before moving on.  It should give you the code and then there will be a pause before it starts the next.   When you see the first code being repeated again you have all your codes.
Marie
    • 2ltr LPG Estate
« Reply #3 on: 28 March 2008, 15:39:10 »
sorry just looked at the video i took and your right it 0505. IACV voltage low or high. i beleive.
ok now what the eml has gone off.
going to check all the electrical connections just to make sure thay are tip top.
rickyboy
  • Glasgow
« Reply #4 on: 28 March 2008, 15:45:49 »
Usually find when there is a code coming and going, it will end up on permanantly eventually but I'd wait to see if it does come back.  No point in making extra work for yourself when there is a chance it's ok.  If you're finding the car having problems with idle then by all means give the valve a clean.
Marie
    • 2ltr LPG Estate
« Reply #5 on: 28 March 2008, 16:05:02 »
ok checked over the car cant see anything, she seems to tick over fine too.
Jase said she drove home fine, the gearbox was ok to still leaking though but no where near as much as he said. still all i can do is top it up again.
well i have to pop to the vx garage and pick up the bits to do the cam cover gasket some time this weekend. and get the spares for next weekend.
cant beleive it next weekend i am going to convert the motor to lpg. wicked
Dazzler
  • Haverhill, Suffolk
« Reply #6 on: 28 March 2008, 16:08:33 »
Good luck with it all Marie ;)
Marie
    • 2ltr LPG Estate
« Reply #7 on: 28 March 2008, 16:12:42 »
Cheers well not going to make it to the garage today but ill go tomorrow moring before vollyball. then if the weather hold out tomorrow pm after vollyball ill tackle it.
rickyboy
  • Glasgow
« Reply #8 on: 28 March 2008, 16:17:33 »
Ahh, joining the world of LPG aren't you the lucky one.  I couldn't go back to filling up with petrol or diesel after using gas.   :y
Marie
    • 2ltr LPG Estate
« Reply #9 on: 28 March 2008, 16:22:10 »
yep that i am.
i cant wait next weekend should be a great one. what with james kev ad me doing it.
must not forget the beer! ;D ;D
« Reply #10 on: 28 March 2008, 16:26:33 »
yep that i am.
::) ;D
Marie
    • 2ltr LPG Estate
« Reply #11 on: 28 March 2008, 16:33:22 »
yep that i am.
::) ;D
opps the LPG conversion that is!
must choose my words wisely with you guys! ;D ;D ;D
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #12 on: 28 March 2008, 16:58:23 »
yep that i am.
[/highlight]
James and Kevin are both teetotal.  ::)
Marie
    • 2ltr LPG Estate
« Reply #13 on: 28 March 2008, 17:01:43 »
yep that i am.
[/highlight]
Dont beleive they are! ;) and i am sure they are going to need it after the work we plan to do!
« Reply #14 on: 28 March 2008, 17:14:17 »
yep that i am.
[/highlight]
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
