Author Topic: Intercooler fan  (Read 3032 times)
cdbdiis
Intercooler fan
« on: 27 March 2008, 09:54:38 »
I noticed a blown fuse in the compartment above the battery (2.5TD) it is yellow and rated at 25A
After some searching around I'm pretty sure it is for the intercooler fan.
Daft question I guess but can anyone please tell me where the actual fan is ? I know where the intercooler is and have had a good look for the fan but to no avail. Thanks
Dazzler
  • Haverhill, Suffolk
Re: Intercooler fan
« Reply #1 on: 27 March 2008, 09:57:26 »
Behind the front grill :-/
Re: Intercooler fan
« Reply #2 on: 27 March 2008, 10:19:18 »
Its mounted on the front of the intercooler in the bottom of the drivers side wing.
They seize up and hence why the fuse has probably blown.
cdbdiis
Re: Intercooler fan
« Reply #3 on: 27 March 2008, 10:29:20 »
Thought that might be the case.
Is the fan obvious ? Because if it is mine has been stolen  :o
I have taken off the small grille at the bottom of the driver side front wing and all I can see is the intercooler.
Is the fan an inline type inside one of the pipes ?
Re: Intercooler fan
« Reply #4 on: 27 March 2008, 10:47:31 »
Yes, its built into a plastic duct that sits on the front of it.
cdbdiis
Re: Intercooler fan
« Reply #5 on: 27 March 2008, 10:57:37 »
Great info  :y
Back into the old clothes again, I'll let you know what I find....
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: Intercooler fan
« Reply #6 on: 27 March 2008, 12:51:10 »
Part No. is 90540637
And they are not cheap (I paid £99 for one from VX dealer)
Original was seized solid with rust so do not expect to be able to salvage it!
IW
Omegatoy
  • UK
Re: Intercooler fan
« Reply #7 on: 27 March 2008, 12:56:57 »
Early ones didnt hav eth I.cooler fan, and i have freed off at least three simply by unbolting the whole intercooler and fan in one lump then carefully working it with penetrating fluid, eventually gets to the stage whee you can put 12v direct to it and then run it for half an hour while still lubricating it, mine is now wired to a switch and i make sure i switch it on at least every coupe of days to keep it free,
mind you with the mountain roads where we live i need it on coming up the hills for the extra power it produces!!!
for those that dont know we live high in the mountains of spain!!! :y
cdbdiis
Re: Intercooler fan
« Reply #8 on: 27 March 2008, 17:52:44 »
Curiouser and curiouser.......
Blown fuse but definately no fan  :-? or no wires leading to it  :-?
Is there an oil cooler fan, could this fuse be for that fan instead ?
Would it be worth retro-fitting an intercooler fan ?
Thanks everyone
« Last Edit: 27 March 2008, 17:54:17 by cdbdiis »
Pitchfork
Re: Intercooler fan
« Reply #9 on: 27 March 2008, 21:06:22 »
Thanks everyone
What year is it??
Re: Intercooler fan
« Reply #10 on: 27 March 2008, 21:32:03 »
Thanks everyone
Fan fitted to later cars only.  It sits just in front of intercooler, which is just in front of drivers side front wheel arch.
Pitchfork
Re: Intercooler fan
« Reply #11 on: 28 March 2008, 10:54:14 »
Thanks everyone
Certainly fitted to an October '96 model!!!
Re: Intercooler fan
« Reply #12 on: 28 March 2008, 21:03:49 »
Thanks everyone
I think fitted to X25DT engines, not U25DT. Thats what I meant by later ;)
cdbdiis
Re: Intercooler fan
« Reply #13 on: 28 March 2008, 21:07:30 »
It's an older '95 M
Would it be worth fitting a fan though ?
Re: Intercooler fan
« Reply #14 on: 28 March 2008, 21:08:29 »
It's an older '95 M
Yes, esp if you can control manually ;)
