Pages: [1] 2 3  All   Go Down
Author Topic: Random Coolant Loss???  (Read 7510 times)
Slime
« on: 28 March 2008, 14:17:22 »
Hi fellas,
I have a '97 V6 manual that suffers from random coolant loss.
It is so random, that if I had hair, I would pull it out!
I sometimes have to top the coolant up after 40 or 50 miles & sometimes it will be fine for 1000 miles!! There seems to be no pattern at all & this confuses me.
I've fitted a new expansion bottle, the old one had a hairline crack around the filler neck, & I've pressure tested the cooling system 3 or 4 times now, with no pressure or water loss.
This problem has been around for over a year now & is really bothering me.
The temp gauge has never gone over 95 degrees C and I'm sure the head gaskets are fine.
Twice I have seen steam appear from under the glove box area & occasionally the screen will suddenly mist up very quickly, mid journey, accompanied by the horrid hot water/anti-freeze smell. When this first occurred I put some paper in both footwells & left the car running for nearly two hours. NO overheating, NO water on the paper & NO dampness on the carpets which makes me think that the heater matrix is okay.
Sorry about the essay & thanks for reading this,
please shed the light,
Slime.
« Last Edit: 28 March 2008, 15:38:12 by Slime »
Dazzler
  • Haverhill, Suffolk
Re: Random Coolant Loss???
« Reply #1 on: 28 March 2008, 14:31:21 »
Have you checked the HBV at the rear of the engine???
There is a guide with pictures in the Maintenance section.
Marie
    • 2ltr LPG Estate
« Reply #2 on: 28 March 2008, 17:57:18 »
Slime
« Reply #3 on: 28 March 2008, 18:01:49 »
Thanks both,
just need to know if there is a way of testing the thing before replacing it?
Slime.
Marie
    • 2ltr LPG Estate
« Reply #4 on: 28 March 2008, 18:05:21 »
you could try and place a peice of kitchen roll around it and take it for a short drive / run it for a while, then removee the kitchen roll and if its wet its leeken.
not sure it would work but its worth a try.
the lads might have some ideas.
« Reply #5 on: 28 March 2008, 18:09:15 »
Thanks both,
Slime.
They're not too expensive to replace. £25/30?
Marie
    • 2ltr LPG Estate
« Reply #6 on: 28 March 2008, 18:11:55 »
Just a bugger to get to and replace!
« Reply #7 on: 28 March 2008, 18:20:50 »
You should be OK .... little hands are just what's needed :y  :y
Marie
    • 2ltr LPG Estate
« Reply #8 on: 28 March 2008, 18:22:08 »
im not doing mine....mine is fine :) :)
« Last Edit: 28 March 2008, 18:22:31 by marie »
« Reply #9 on: 28 March 2008, 18:24:14 »
......mine is fine :) :)
So's mine ..... now. ;)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #10 on: 28 March 2008, 18:30:14 »
I think mine might be shot......
....and I have huge hands!!!  Getting to the DIS was like a Krypton Factor challenge for me!
« Reply #11 on: 28 March 2008, 18:33:03 »
The HBV is a little easier in that you can at least see the bugger when the scuttle is removed. The first I saw of my DIS pack was when the final bolt had been removed.  ;)  ;)  :y
Slime
« Reply #12 on: 28 March 2008, 18:33:24 »
Me got big hands,  fingers like bananas,
Slime
Gaffers
« Reply #13 on: 28 March 2008, 18:43:25 »
Slime
Must be from the same stock as me.  Irish blood?
Marie
    • 2ltr LPG Estate
« Reply #14 on: 28 March 2008, 18:44:59 »
get your wives to do it!
they have small hands ;D ;D ;D ;D ;D
Pages: [1] 2 3  All   Go Up
