Author Topic: vauxall omega elite 3.2 satnav  (Read 2106 times)
ron
  • chelsea sw35bl
« on: 03 April 2008, 20:05:42 »
so nobody can help me satnav will not work in my car tried everything if somebody would like to come and try your welcome tried updates cannot calculate looked at all the sites please can somebody help
Re: vauxall omega elite 3.2 satnav
« Reply #1 on: 03 April 2008, 20:46:31 »
Giving some clue as to what is wrong, and what you have tried, along with the satnav type will be a great help.
« Reply #2 on: 03 April 2008, 20:52:56 »
I have the 2013 and the satnav works OK .. but the tomtom is better.
Question .. do you have the "right" CD for your system ?? there are several "variants" on ebay... and the wrong one will not work !!, and some of the ebay sellers lie ... or don't know what they are doing ( being generous) .. I found that out the hard way.. but got my money back  :) ( 'cos I can be "not nice" )
    • 530D M Sport, 330i Coupe
« Reply #3 on: 03 April 2008, 22:11:50 »
If the CD is correct and the system can't calculate a route then it probably doesn't know where it is at the moment, if that is the case then I would guess it hasn't got a GPS fix which will be down to no connection to the GPS antenna.
3 main connection points to check, back of head unit/cage, link behind right hand kick panel and I think there's one at the base of the antenna (Under headlining).
If you can give a full description of the fault it would help.
« Reply #4 on: 03 April 2008, 22:13:53 »
And if its an NCDC series radio, it most likely the connection behind the stereo, as the cage often distorts, resulting in poor connection.
ron
  • chelsea sw35bl
« Reply #5 on: 03 April 2008, 22:51:22 »
hi thanks for the help it is a ncdc 2013 radio the gps stays red could be the arial reception probaly cant get a fix that is why it cant calculate distance im new to this game how can i get at radio to check satnav connection
« Reply #6 on: 03 April 2008, 22:58:43 »
Four allan grub screws need to be removed then a set of double din radio keys (from Halfords or similar) should allow you to pull the unit out.
Make sure you have the correct car pass (usually in the folder with the manuals) before removing the head unit.
If the GPS logo in the top right hand corner of the colour screen is red then you definately have no GPS signal.
ron
  • chelsea sw35bl
« Reply #7 on: 03 April 2008, 23:01:50 »
thanks is definatley red does it go green if on?i have allan keys and card pass
« Reply #8 on: 03 April 2008, 23:03:38 »
Amber for 2d fix and green for 3d fix.
Red means it hasn't got a fix which is a reception issue.
« Reply #9 on: 04 April 2008, 11:26:53 »
And 9/10 its always the connection at back of headunit, due to distorted cage!
ron
  • chelsea sw35bl
« Reply #10 on: 05 April 2008, 13:53:55 »
well took out the radio jiggled the cage now gps green and working fine thanks to everyone for there help and guidance ron
