Author Topic: EML light  (Read 1071 times)
f13platform
  • birmingham
  • f13..
EML light
« on: 08 April 2008, 19:22:10 »
come on today engine went off few time
checked the code it was
camshaft sensor and air flow sensor
replace both of them but camshaft sensor was out off order
b'use the camshaft code stayed on code reader
EML is still on until tomorrow change it
is that ok drive the car now?
what happen they both fail at the same time?
« Last Edit: 08 April 2008, 19:23:33 by f13platform »
rickyboy
  • Glasgow
Re: EML light
« Reply #1 on: 08 April 2008, 19:24:50 »
Should be able to drive it, only problem you may encounter is a rev limiter at 4000rpm.  The airflow sensor fault will probably disappear when you change the camshaft sensor.  Likely to stall alot if the airflow sensor was a problem.  Change the camshaft sensor and you should find all is well.
