Author Topic: Been searching but couldn't find......  (Read 1781 times)
Amego52
  • Too near lakeside for comfort!
« on: 08 April 2008, 18:50:38 »
....how to roughly set the camber after new suspension units.  Can anybody point me in the right direction, I'm sure i've read it on here somewhere :'(
I love my Omega-I Hate my Omega-I love my Omega-I hate my Omega
Steve1077
Re: Been searching but couldn't find......
« Reply #1 on: 08 April 2008, 20:56:49 »
Why would you need to?
Danny
  • Wigan, Greater Manchester
« Reply #2 on: 08 April 2008, 21:16:21 »
most members speak to Tony at Wheels In Motion, a company that does full 4-wheel alignment and geometry, others who arent local to Wheels In Motion... they drive all the way down there cos he's worth it!
there's also a place in Oldham Manchester (recommended by Tony for those unable to travel down south to him from here) and also you may find a local tyre place to yourself that might have the equipment to do the same as WIM does, I have my own local one about 5 miles from me
Olympia5776
  • Ireland
« Reply #3 on: 08 April 2008, 21:33:06 »
I posted a write up on fitting front camber adjusting bolts on March 3 which included the method I used to adjust and set my camber.
I've had no problems since the car drives perfectly and the new tyres fitted are wearing evenly.
WIM are no doubt the Guru's at alignment and camber but you guys have to remember that not all of us within easy reach of Watford. ;)
« Reply #4 on: 08 April 2008, 21:47:55 »
As a rough guide, slacken the bolts and pull the tops of the tyres fully out (minimum camber) and then let the top bolt back about 4mm in the top slot.
I use a spirit level with some screws fitted as a basic gauge but, got it set properly recently at a local geometry place.
justme
  • Shadowland
  • Testing by TB
« Reply #5 on: 08 April 2008, 22:43:21 »
You dont need any of the gismos available.
2' spirit levell bolt at either end, 1 long enough to miss centre cap the other 8.86mm longer, this is for a 16" wheel, make sure it is fully loaded as recommended (full tank, 70Kg on rach front seat). Deadly accurate as per wheels in motion recommendations. for larger wheels do the calc, after reading Tony's recommendations.
wonderfull formaly 3.172 or pi
Test sig...
damon80
  • Wigan
« Reply #6 on: 09 April 2008, 15:41:29 »
Where's the place in Wigan that does the 4-wheel alignment and geometry check Danny?
« Reply #7 on: 09 April 2008, 19:18:44 »
If you're going to use spirit levels, make sure it's on a reasonably flat garage floor first. :y
