Author Topic: Remote Locking  (Read 4996 times)
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: Remote Locking
« Reply #15 on: 04 February 2008, 19:38:03 »
I would suspect the solder joint between the circuit board & the battery contact
It's worth resoldering to eliminate that as the cause
Takes seconds to do
Dazzler
  • Haverhill, Suffolk
Re: Remote Locking
« Reply #16 on: 04 February 2008, 19:41:57 »
Did you check the battery holder as suggested?
Eliteman Steve
  • Brighton
Re: Remote Locking
« Reply #17 on: 04 February 2008, 22:51:01 »
The battery holder bent a little as I was taking the battery out but didnt seem to be damaged at all , will have a closer look at holder and soldered joints tomorrow :y
Eliteman Steve
  • Brighton
Re: Remote Locking
« Reply #18 on: 05 February 2008, 13:37:42 »
Takes seconds to do
Nice one Pitchfork :y
Had a closer look at key today and had a poke around , thought as key's not working got nothing to loose anyway one of the contacts was broken .  :D
Thinking back I dropped the key just before it stopped working so maybe this broke the connection in the first place :(
Still don't know why the key re-set with key in ignition doesn't seem to work though , nothing happened with either key . Never mind happy now got 2 functioning keys again [smiley=laugh.gif] [smiley=laugh.gif]
alasdaircantlay
  • Glasgow
Re: Remote Locking
« Reply #19 on: 12 April 2008, 20:36:47 »
On my 98 TD estate, you have to switch the engine on and press the close button on the remote within 30 seconds to re-sync the key. Central locking pops up and down to tell you it's been done. I have to re-sync it on a daily basis though.  :(
