Author Topic: Bumped my bumper...  (Read 1882 times)
alasdaircantlay
  • Glasgow
Bumped my bumper...
« on: 12 April 2008, 19:24:51 »
I smacked the back of someone else when they started moving at a set of lights, then decided to stop. I have cracked my bumper and the screenwash bottle pump was loosened when it was driven back into a fan of some type. I took the bumper off this afternoon and there is a big metal bar type thingy which is all bent out of shape. I've tried my best to straighten it to some degree but it doesn't actually go back on properly. Can I get a replacement part? And how important is it to have both the fans in front of the radiator working? Can I get a matching bumper kit too? Sorry for all the questions. Please bear in mind I know hee-haw about cars too... It's a '98 2.5 TD S Estate, in silver.
« Last Edit: 12 April 2008, 19:27:18 by alasdaircantlay »
HolyCount
Re: Bumped my bumper...
« Reply #1 on: 12 April 2008, 19:30:04 »
« Reply #2 on: 12 April 2008, 19:34:15 »
The fans are critical on the TD, as the engine will crack its head if it overheats.  These are the only 2 electric fans for cooling, and also come on with A/C
alasdaircantlay
  • Glasgow
« Reply #3 on: 12 April 2008, 19:50:56 »
That certainly is the bit on ebay! Thank you! And I'll have to check the fans are working again as I assume they only come on when the engine is up to temp. I managed to free the one that was not moving but whether it is turning remains to be seen. I assume they're quite easy to get if needs be?
HolyCount
« Reply #4 on: 12 April 2008, 19:54:02 »
If you post a wanted on the forum ( in the parts for sale and wanted section ) there are sure to be members breaking and hopefully will have the part(s) you need
« Reply #5 on: 12 April 2008, 21:00:44 »
No, they are an utter pig to replace - rad and a/c condensor out.
I have 2 in the garage.
alasdaircantlay
  • Glasgow
« Reply #6 on: 12 April 2008, 21:03:20 »
I don't have a/c in my beast so it shouldn't be too bad? Fingers crossed!
« Reply #7 on: 12 April 2008, 21:05:29 »
Ah, not too bad then.  Rad out.
alasdaircantlay
  • Glasgow
« Reply #8 on: 12 April 2008, 21:09:58 »
any hot Omega mechanics in Glasgow that you know about? There's an Arnild Clark Network Q place right round the corner from me, but they're not cheap! And I'm skint!
