Author Topic: OVER REVVING  (Read 2062 times)
opelsr
  • suffolk
OVER REVVING
« on: 12 April 2008, 23:45:32 »
hi i have an intermittent problem 2.5 v6  /r reg , Evey so often the revs pick up on their own upto about 2500/3000 then it will sit at that for a few minutes then drop back down to normal if the car is standing.  If i am driving it it sometimes cuts out altogether when the revs drop  .It will start again after it has done this.I  am going to do paperclip test tommorow, but a few pointers in the right direction would be great .
Danny
  • Wigan, Greater Manchester
Re: OVER REVVING
« Reply #1 on: 12 April 2008, 23:47:26 »
throttle body needing a clean?
Idle Control Valve needing a clean?
« Last Edit: 12 April 2008, 23:48:02 by D4NNY »
adsomega
  • swanley  kent
  • banned due to bad trader references
Re: OVER REVVING
« Reply #2 on: 12 April 2008, 23:49:29 »
i agree with danny  a good place to start
opelsr
  • suffolk
Re: OVER REVVING
« Reply #3 on: 13 April 2008, 00:08:50 »
WHERE WILL I FIND THE IDLE VALVE SORRY TO ASK BUT HAVE NOT WORKED ON THIS CAR VERY MUCH
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: OVER REVVING
« Reply #4 on: 13 April 2008, 00:18:23 »
There is a maintenance giuide to the icv clean and also the throttle body as well. also see the guide on cleaning the breathers at the same time. :y
Jaguar XJ6
opelsr
  • suffolk
Re: OVER REVVING
« Reply #5 on: 13 April 2008, 00:22:19 »
CHEERS I  WILL HAVE A LOOK AT GUIDE AND HAVE A GO TOMMOROW
THANKS FOR YOU HELP
Re: OVER REVVING
« Reply #6 on: 13 April 2008, 00:25:52 »
it is a silver canister type thing beside the oil filler,it plugs into the side of the plenum.clean it with carb cleaner (wynns is very good) then lubricate with light oil-wd40 or similar.
