Author Topic: Noise around cambelt area  (Read 4959 times)
peterjohn36
  • Fareham
« on: 07 April 2008, 09:28:47 »
Have noticed a slight  dry sound to a rattle around the middle of the cambelt area the last couple of days, I am due a new belt assy within the next three thousand miles, so phoned my car mechanic up this morning and have it booked in for Thursday, for the belt and tensioners, also the water pump, this is the item that I think could be on the way out, as at the 40k mark the pump was not changed so its comming up to the 80k mark, am I correct in thinking this could be it, are they a common fault to go around the 80k mark. I can only think by changing every thing around that area should remove the fault, unless you have any other ideas.
Pete
Re: Noise around cambelt area
« Reply #1 on: 07 April 2008, 09:49:13 »
Pete
To see if it is the pump, remove aux belt and run for a max of 20s or so. If no noise, then must be something driven by aux belt.
Worth changing pump anyway at next cambelt
« Reply #2 on: 07 April 2008, 09:49:54 »
I'm assuming v6 - you dont say?
ricardo1500
  • Wolverhampton
« Reply #3 on: 07 April 2008, 09:53:46 »
Just been through this very scenario and my noise turned out to be the water pump....and mine was changed only 7-8000 miles ago
peterjohn36
  • Fareham
« Reply #4 on: 07 April 2008, 11:19:45 »
Sorry forgot to mention its a 2.2  only 4cyl
Pete
« Reply #5 on: 07 April 2008, 13:58:26 »
Pete
Ah.  Cambelt driven pump then.  I wouldn't be taking any chances!
« Reply #6 on: 07 April 2008, 14:00:03 »
Pete
I have seen pumps fail around 60k mark.... i would get that all changed ASAP cause as mentioned water pump is cambelt driven.
« Last Edit: 07 April 2008, 14:00:42 by tunnie »
Taxi_Driver
« Reply #7 on: 07 April 2008, 14:54:46 »
On my 2.2 the original water pump didnt get as far as 60k......it was in the 50's k when the bearings started to go.......so for the cost of water pumps worth doing every 40k along with cambelt  :y
peterjohn36
  • Fareham
« Reply #8 on: 07 April 2008, 17:38:58 »
Thanks for all the replies, have taken the car of the road, dont want to chance a busted engine, will only be used to drive the 3 miles to the car mechanic on Thursday. better safe than sorry.
Pete
« Reply #9 on: 07 April 2008, 17:47:09 »
Pete
Of course, you could always do cambelt and pump yourself and save lots of pennies!
Whichever way, its cambelt kit, not just cambelt that needs doing.
peterjohn36
  • Fareham
« Reply #10 on: 07 April 2008, 18:24:03 »
Pete[/quote]
Whichever way, its cambelt kit, not just cambelt that needs doing.[/quote]
Might sound odd, but have not worked on a car since I sold a Landrover that would about 8 years ago, spent many hours repairing and the odd welding jobs on it a true off roader of the road more than on LOL, when I went back to cars I thought I would give the spanners up, and have used the same car mechanic since, thanks for the advise about the camshaft kit, he will be fitting the kit with a new water pump.
Pete
« Reply #11 on: 07 April 2008, 19:07:28 »
Pete
Marie is always around the corner! :y She likes to get her Hands dirty. ;D  ;D
« Last Edit: 07 April 2008, 19:09:08 by Andy_B »
peterjohn36
  • Fareham
« Reply #12 on: 11 April 2008, 20:00:13 »
Well, placed the Omega in on Thursday for repair, was told how lucky I was not to have a wrecked engine, it was the water pump, one part had fallen of on it and must have got caught with the cambelt as the belt had a chunk out of it about a third of the width, when he took the cover of I was amazed at seeing the problem, so the moral is change the water pump at the same time as the cambelt assy( which I can say was not done at its last change as this pump must have done 76k), he changed the tensioners as well, but they still seemed fine. The car is now running like a dream again.
Pete
Taxi_Driver
« Reply #13 on: 11 April 2008, 20:53:22 »
Lucky escape then.......good job you didnt carry on driving it.
Glad its sorted now  :y
Marie
    • 2ltr LPG Estate
« Reply #14 on: 12 April 2008, 07:57:10 »
Thats lucky!
If you ever need anything i am only around the corner from you. Your welcome to bring your car round for me to have a look next time you get a snag. ( although i only have a limited knowledge of your engine).
