Author Topic: Air filter  (Read 2152 times)
prestigesec
  • Wirral
Air filter
« on: 14 April 2008, 13:41:43 »
Whats the best air filter for 3.0L V6 omega standard air box with uprated filter or an uprated cone filter??
Re: Air filter
« Reply #1 on: 14 April 2008, 13:52:41 »
The standard filter is plenty big enough not to be restricting the engine. Cone filters just give you more noise (and less power unless you're careful to ensure it only breathes cold air).
Re: Air filter
« Reply #2 on: 14 April 2008, 13:56:33 »
Std generally gives best performance as its pretty big.
Avoid oil filters, rumours are that they reduce life of MAF
prestigesec
  • Wirral
Re: Air filter
« Reply #3 on: 14 April 2008, 14:03:44 »
How does an oil filter reduce the life of your MAF? Or was that a miss type? I have usually just swapped the standard panel filter for a jetex panel filter on cars i have had before and always had good results just wondered about the v6 thats all.
Dazzler
  • Haverhill, Suffolk
Re: Air filter
« Reply #4 on: 14 April 2008, 14:10:30 »
He means oil coated air panel filters like K&N etc....
prestigesec
  • Wirral
Re: Air filter
« Reply #5 on: 14 April 2008, 14:16:12 »
Gotcha, had that problem with my subaru went with an apexi dry cone filter with fantastic results
Dazzler
Re: Air filter
« Reply #6 on: 14 April 2008, 14:20:43 »
If your going cone filter make sure you have a walled off cold air inlet for it or it will have the opposite effect ;)
prestigesec
  • Wirral
Re: Air filter
« Reply #7 on: 14 April 2008, 14:22:15 »
I will stick with panel if its good enough, only went to a cone on the scoob cause i had a front mounted intercooler fitted and it had to be cone
Re: Air filter
« Reply #8 on: 14 April 2008, 14:24:42 »
Yup, my bad. Servers me right for being on the phone, building a server, and OOFing at the same time  :-[
Many cones on Omega reduce power. Partly due to difficulty in getting cold air, and partly in getting enough surface area.
prestigesec
  • Wirral
Re: Air filter
« Reply #9 on: 14 April 2008, 14:26:23 »
No probs, by the way how on earth do you manage to get 27000 post are you on here constantly  ;D
Re: Air filter
« Reply #10 on: 14 April 2008, 14:46:39 »
As a responisble Admin, I'm always online :P
