Author Topic: MV6 - oh cock.  (Read 6936 times)
Re: MV6 - oh cock.
« Reply #30 on: 14 April 2008, 10:23:11 »
Ow yes, I have a set of head bolts you can have......and some re-furbed exhaust manifolds which will make the job much easier.
Excellent, thanks MDTM :y
Do the refurbed heads have manifold studs in - at least one of mine looks to be broken  :'(, or do I need to buy some of them?
Re: MV6 - oh cock.
« Reply #31 on: 14 April 2008, 10:25:00 »
You could fit new ones but, I have enough to fully populate both sets with good second hand items.
Re: MV6 - oh cock.
« Reply #32 on: 14 April 2008, 10:37:39 »
I'm all for keeping costs to a minimum (without bodging) :y
Re: MV6 - oh cock.
« Reply #33 on: 14 April 2008, 13:10:01 »
Good luck with the job.. :y
Re: MV6 - oh cock.
« Reply #34 on: 14 April 2008, 13:51:40 »
Are these all the genuine parts I need to get:
2 x GASKET, MANIFOLD TO CYLINDER HEAD X25XE, X30XE   24416110
2 x GASKET, COVER TO CYLINDER HEAD (CONSISTS OF 2 PIECES) 90511451
16 x  'O'RING    90411826
2 x GASKET, FRONT PIPE TO MANIFOLD X25XE, X30XE   90499289
4 x SEAL, RING, 16 X 20, OIL COOLER PIPE TO RADIATOR  11076852
1 x SEAL, RING, WATER INLET NECK TO CYLINDER HEAD  9128362
4 x SEAL, RING    12992647
Pretty certain I have the sealants already, might not have the green, so need to double check.
Probably worth changing stat at same time, stick with a genuine stat?
    • 530D M Sport, 330i Coupe
Re: MV6 - oh cock.
« Reply #35 on: 14 April 2008, 13:53:38 »
Ideal oportunity to make a DVD??
« Last Edit: 14 April 2008, 13:54:14 by VXL_V6 »
Martin_1962
Re: MV6 - oh cock.
« Reply #36 on: 14 April 2008, 13:59:37 »
I will need to do mine sometime - valve stem seals :( >:(
Re: MV6 - oh cock.
« Reply #37 on: 14 April 2008, 14:00:13 »
Looks about right, would need to check the numbers.
Re: MV6 - oh cock.
« Reply #38 on: 14 April 2008, 14:02:28 »
The dowty ones (bottom ones) are the ones I wasn't too sure of - seemed to be quite a few options with filtering off, but only those with filter on (bit distrusting of the filtering).
Re: MV6 - oh cock.
« Reply #39 on: 14 April 2008, 14:07:36 »
And to change stat:
1 x THERMOSTAT, ASSY.  90502201
1 x SEAL, RING, HOUSING 9128363
2 x SCREW, M8 X 18, THERMOSTAT HOUSING TO CYLINDER BLOCK 11093601
1 x PIPE, THERMOSTAT HOUSING TO HOSE    90411629
2 x SEAL, RING  90410899
Dazzler
  • Haverhill, Suffolk
Re: MV6 - oh cock.
« Reply #40 on: 14 April 2008, 14:09:10 »
How about 4x camshaft seals?? genuine
Re: MV6 - oh cock.
« Reply #41 on: 14 April 2008, 14:15:43 »
And to change stat:
Stat housing should have the seal ring with it.
I have the bolts
I have a spare bridge pipe to.
Dazzler
Re: MV6 - oh cock.
« Reply #42 on: 14 April 2008, 14:22:21 »
You probably already know this but, if fitting a new stat and housing you will need shorter bolts as they have reduced the flange thickness by a country mile >:(
Re: MV6 - oh cock.
« Reply #43 on: 14 April 2008, 17:26:36 »
re-seal the oil cooler plate and coolant bridge while your down there?
Did seam to be weaping a bit.
Mike Collins
  • North of Bristol
Re: MV6 - oh cock.
« Reply #44 on: 14 April 2008, 18:02:14 »
The thermostat I bought recently, genuine, did not come with the seal.
Pages: 1 2 [3] 4  All   Go Up
