Author Topic: Changing seat belt pre-tensioner - any probs?  (Read 1816 times)
kevin61
  • York
« on: 11 April 2008, 21:09:00 »
My seat belt buckle jammed inside due to a rogue bit of plastic getting caught in the mechanism.  To fix it I ripped the plastic covering apart, removed said bit and wrapped the thing in gaffer tape.
It works fine again but I was wondering if it is difficult to replace (with a second hand one) bearing in mind explosive content etc.
Thanks.
P.S. Just spent two hours reading FAQs etc.  Excellent informative stuff - now can I have a free sticker?
Chopsdad
  • Bouncy Castle in Carlisle
  • Keep it clean!
Re: Changing seat belt pre-tensioner - any probs?
« Reply #1 on: 11 April 2008, 21:22:54 »
Thanks.
Of course you can - just send £2.50 for p&p :y Click here http://shop.omegaowners.com/
Mike Collins
  • North of Bristol
« Reply #2 on: 11 April 2008, 22:09:31 »
Pretensioner change requires seat removal, not difficult but you need to disconnect the battery and leave it for a while before removing the connectors.
If it has electric fore and aft adjustment, you will need to remove the bolts before disconnecting unless you like lots of winding with the crank.
kevin61
  • York
« Reply #3 on: 12 April 2008, 00:10:35 »
Thanks for the tip but I don't quite understand this sentence, not having removed anything yet.  Can you elaborate? Remove which bolts?
Cheers
(Goes looking for £2.50 in the rear seat cushions.)
Mike Collins
  • North of Bristol
« Reply #4 on: 12 April 2008, 09:00:42 »
The four torx headed bolts that hold the seat to the floor, you have to move the seat backwards and forwards to access the heads. If the seat is full electric, you will have to use the crank tool if the power is off. If it's manual, just slide it.
kevin61
  • York
« Reply #5 on: 12 April 2008, 09:27:23 »
Brilliant.
Thanks Mike.
HNO3GOH
  • Somerset
  • Play time.
« Reply #6 on: 12 April 2008, 12:41:43 »
Just watch the one bolt at the front near the centre console on both sids as that can be a bit of a sod to get out due to being a bit tighter than the rest. :y
kevin61
  • York
« Reply #7 on: 14 April 2008, 21:27:24 »
Cheers
 [smiley=dankk2.gif]
