Author Topic: Vac pipe renewal??  (Read 1538 times)
cbs2
  • East Kilbride
  • Right....Fire Up The Quattro!!!
Vac pipe renewal??
« on: 15 April 2008, 10:07:34 »
Got a couple of ropey looking vac pipes
is it possible to buy the pipe by the roll, metre etc or are the pipes a dealer part??
Taking part in the 2010 sucata split charity banger run. www.sucatasplit.com
www.boozebrothers2010.co.uk
Ex-mig owner................For now
Dr Jones
  • Wantage, Oxfordshire
Re: Vac pipe renewal??
« Reply #1 on: 15 April 2008, 11:49:59 »
The rubber pipes? They seem to degrade really badly, have done on mine anyway.
I've used the same rubber hose as you get on the diesel spill pipes - as long as it's about the same diameter it's OK to use
It's about £1 per foot or so - connectors are 6p onwards
If you're not living life on the edge, you're taking up too much space!
cbs2
  • East Kilbride
« Reply #2 on: 15 April 2008, 16:36:02 »
I think they are for the multi rams??
come up the side of the bellows, over the pass side bank to the rear of the engine.Black plastic about 4-5mm dia if that helps
