Author Topic: 2.5 v6 wont start please help  (Read 1258 times)
filterdal
  • essex
« on: 15 April 2008, 11:07:08 »
car wouldnt start this morning has started first time allways ,but battery died before it would start ,was very cold this morning and car is probally fed up of the bloody weather but. will take of my battery and charge it up any problems related to battery disconect ? will buy new one at weekend . also if it doesnt start any ideas from anyone why it would just not start have a 2001 2.5 v6 has 49000 miles thanks
Re: 2.5 v6 wont start please help
« Reply #1 on: 15 April 2008, 11:10:11 »
Read the stored fault codes in the ECU.....might be a code 19 stored.
Here is a link to a how to:
http://www.omegaowners.com/forum/YaBB.pl?num=1152601768
Dazzler
  • Haverhill, Suffolk
« Reply #2 on: 15 April 2008, 15:37:55 »
As Mark says^^^^^
If it is code 19 replace the crankshaft sensor and it should roar into life again.
Taxi_Driver
« Reply #3 on: 15 April 2008, 18:45:24 »
Only if you dont have the car pass......ie radio/cd will want the code entered for it to work again.
Windows will want 'one touch' learning done on them and i believe sunroof will too if you have one.
Remember if you have a power sounder fitted.......loosen batt terminals....turn ign on then off........you will have then 10/15 secs to whip the batt terminal off, so the power sounder doesnt go off  :y
