Author Topic: 3.0 Flywheel swap and other tuning  (Read 8219 times)
Sideways
« on: 05 September 2006, 08:17:45 »
Hi Guys
I was chatting to Terry the other day and he mentioned he was dropping an Astra flywheel into his MV6.
I was planning the same job but with the Courtenay flywheel, which obviously is significantly more expensive (£260).
Can anyone give me some advice on the Astra method. Exactly what Astra is it from, is it difficult to do, are there any other consideration I should bear in mind before tackling this task., what is the weight difference (I think the 3.0's is around the 15Kg mark).
Also, I was having a gander at the V6 area of Courtenay's website and they offer quite a few upgrade products (leads, plugs, fuel pressure regulator, thermostat etc). Does anyone have any knowledge or experience of these.
Thanks in advance.
omegaV6CD
  • Darlington
Re: 3.0 Flywheel swap and other tuning
« Reply #1 on: 05 September 2006, 22:56:51 »
Hi Guys
Thanks in advance.
I think what terry wants to use a flywheel from a C20XE engine which can be found under the bonnet of calibras, cavalier, astra mk2 GTE, mk3 GSI etc. Yes the light flywheel will reduce the inertia of the rotating masses of the engine but it will do f*** all with regards to horsepower, i wouldn't do it last after i have exhausted all other improvement opportunities with regards to engine performance.
I think what courtenay offers is okish with a tendency for high cost useless modifications such as upgrade plugs, water wetter, airbox buchering etc. I used the cool stat once in my old omega with very good results as the car feels more powerfull when below 93 degrees. Wait untill february when i will be carrying major tuning DIY work and i will let you know what is what.
Tezray
« Reply #2 on: 05 September 2006, 23:16:38 »
Hi Mark, yes i've bought an early type (flat style) flywheel and clutch from a C20XE (redtop) engine. I think the dual mass flywheel may even weigh as much as 18kg's? But the xe flywheel weighs 8.5kg's! Obviously this won't do anything for my HP and infact will knock my high end torque, but it should pull through the revs quicker and from lower down. As for cost, mine set me back £30 delivered  ;D And i've been told the standard xe clutch should handle the power and not wear out quickly like i first thought.
As for other performance mods, i wouldn't touch a fuel pressure reg. The fuelling on the V6's is perfect for a standard engine, anything more would probably over-fuel it and actually slow you down. I nearly went for a cool stat. when rebuilding mine because as OmegaV6cd said, the V6's are noticeably quicker at around 92-93 degree's. For a free/cheap mod i'd be tempted to butcher the airbox slightly and get a cold air feed running to it....Or get a carbon fibre surrounded filter, like a BMC can.
Still need to meet up! But i'm really busy lately, working from 10-6 Mon-Sat  ::)
rpont
  • Tadcaster
« Reply #3 on: 06 September 2006, 07:34:08 »
Isn't there already a cold feed to the airbox? On mine there is a pipe that connects to the front of the airbox and goes around in front of the radiator, just behind the grill.
Sideways
« Reply #4 on: 06 September 2006, 07:36:31 »
Yes there is, though I'll probably do away with this altogether and have straight induction into the throttle bodies via an air filter and do away with the multiram or have a direct feed into the airbox from a more sensible location and profile than the standard intake pipe.
rpont
  • Tadcaster
« Reply #5 on: 06 September 2006, 21:52:34 »
I think you probably need to think this through a bit. If you do away with the cold air intake and go for straight induction won't you then be pulling in hot air after it's been through the radiator? If you get rid of the multiram you will need to reprogram the ECU otherwise it's going to think the multiram has failed and go into limp mode I think. Both of which will reduce your performance.
A lighter flywheel is only likely to be of benefit if you have an auto, it will be able to speed the engine up quicker for down changes but it's not going to make any difference to the power or torque that the engine can provide.
Paul M
  • Edinburgh
« Reply #6 on: 06 September 2006, 22:32:34 »
WTF... I don't think you have a flywheel with an auto!?! You've got that great big sodding torque converter and its associated inertia.
The reason for lightening the flywheel is to reduce the intertia (effectively angular weight) that the engine has to spin. So even though it produces no more power, that power can accelerate a lower angular mass more quickly (and slow more quickly too).
There are of course downsides, not least of which is reduced damping effect causing a reduction in smoothness, but also potential engine damage if the flywheel is design to dampen harmonics from the crankshaft! I don't know enough about the Omega setup to comment with any authority though...
Sideways
« Reply #7 on: 07 September 2006, 07:26:55 »
That's a very good point. Might give that some consideration.
Re the direct induction I will move or modify the radiator to allow straight cold flow, or just put a bonnet scoop on.
Omega-MV6
  • Calne, Wiltshire.
« Reply #8 on: 07 September 2006, 08:00:01 »
That is exactly what I was planning to do. 8-)
Maybe get hold of a Monaro style bonnet vent.
I think it would be possible to run the straight induction to the TBs, providing all the Multi-Ram parts are still in place.
Duel Filters are probably out of the question, as there is only one MAS, maybe just one huge filter behind the new bonnet vent.
Still drawing up plans, and measuring stuff.
Main problem at this point is to find a filter of the correct size...a K&N Filter though, not some other random make.
**I wonder if I could use the existing airbox**  :-?
Cheers.
Matt
There are only 10 types of people in the world.....
......Those that understand binary, and those that don't
Sideways
« Reply #9 on: 07 September 2006, 08:16:36 »
Sounds good Matt
I reckon K&N or Pipercross would make ayou one to spec.
Or you could just buy the foam then make it yourself. It's not that difficult.
« Reply #10 on: 07 September 2006, 09:19:05 »
Dont get an oiled filter thoughk, the oil knackers the MAF sensors.....
Omega-MV6
  • Calne, Wiltshire.
« Reply #11 on: 07 September 2006, 11:14:21 »
I have a K&N panel filter ATM, it's slightly oiled.
The next one I get will defo be a PiperCross viper though
I kinda have 3 choices really:
Either use a scoop on the bonnet, Monaro Style - Would look cool, but a lot of work involved
Use the front airdamn - An awfult lot of re-plumbing the intake system, but would be very discrete
Or vent the wing, next to the existing airbox - Althouth the twin intake pipes would remain in place, the "induction kit" (Piper x make a good one), would be fed by a vent either on the bonnet or on the wing.
On the Fly Wheel front, the weight saving is your biggest asset there, although accelaration will be helped a fair bit, but no direct BHP increase.
Thats why F1 engines rev so quickly, as they have have berly no flywheel.
But be carful as Flywheels are often balenced for a specific engine, to help it run smoother, and iron out any shakes etc... you may have to re-balance your new one.
Cheers.
Matt
Sideways
« Reply #12 on: 07 September 2006, 11:28:48 »
Reckon the bonnet scoop would be the neatest or just drop your rad by 4-6 inches.
I'd love to see it when your done. What else are you doing to it?
rpont
  • Tadcaster
« Reply #13 on: 07 September 2006, 11:43:25 »
It hadn't occurred to me that the auto wouldn't have a heavy flywheel, it could just have a light starter ring.
I did think about the angular mass slowing the acceleration but I'm not sure what difference knocking a few kgs off that will make to acceleration. I know my auto doesn't take long to accelerate the engine alone but I've never compared it to how long a manual takes.
Don't get me wrong, I'm not knocking the idea, I'm just interested in what difference it would make.
« Reply #14 on: 07 September 2006, 11:45:15 »
Not convinced you'll see much performance benefit from modded intakes....
