Author Topic: sumps for V6's  (Read 2603 times)
Jay w
  • Plymouth/Poole
  • omega gone
sumps for V6's
« on: 17 April 2008, 20:13:47 »
We are in the process of fitting the RWD sump to a FWD engine, now i was under the impression that there were gaskets fitted to the mating faces.
VX claim that it is just black sealant, can anyone confirm if there are gaskets and what the Pt number should be.
Thanks
Dazzler
  • Haverhill, Suffolk
Re: sumps for V6's
« Reply #1 on: 17 April 2008, 20:21:17 »
Jay, it shows a gasket with no refrence, it seems its been superseeded by a sealent p/n- 93165267
Hope this helps
Jay w
  • Plymouth/Poole
  • omega gone
Re: sumps for V6's
« Reply #2 on: 17 April 2008, 21:01:00 »
cheers mate, it would seem that the dealer was speaking the truth after all......
just got to source a sump now  >:(
Dazzler
Re: sumps for V6's
« Reply #3 on: 17 April 2008, 21:03:30 »
Have you asked in the wanted section, im sure NMarkieMark or Chris will have one or there is an Omega breakers near Heathrow airport :-/
Re: sumps for V6's
« Reply #4 on: 17 April 2008, 21:03:44 »
...........had to happen sometime i suppose  ;D
Jay w
  • Plymouth/Poole
  • omega gone
Re: sumps for V6's
« Reply #5 on: 17 April 2008, 21:05:53 »
cheers mate....
spoke to the breakers in Heathrow, they have nothing currently which is a shame cos i could have picked it up on the way home.
i am going to put a wanted ad up, its my fault i shouldn't have revved the nuts out of the engine  :-[
Dazzler
Re: sumps for V6's
« Reply #6 on: 17 April 2008, 21:12:39 »
Have you put a hole in the sump then???? :-/
Jay w
  • Plymouth/Poole
  • omega gone
Re: sumps for V6's
« Reply #7 on: 17 April 2008, 21:13:53 »
no, a piece of flying debris took a chunk out of the inside of the sump  ;D :o
« Last Edit: 17 April 2008, 21:14:18 by jay_w »
Dazzler
Re: sumps for V6's
« Reply #8 on: 17 April 2008, 21:21:31 »
Repairable with JB Autoweld :-/
Jay w
  • Plymouth/Poole
  • omega gone
Re: sumps for V6's
« Reply #9 on: 17 April 2008, 21:23:51 »
i wouldn't want to take the chance, if it doesn't hold then it is the whole sump off again as it is the upper part i have damaged.
I'm going to post some piccy up of the damage on the weekend  ;D 8/10th's of a conrod, a 6 piece piston, a remodelled big end ;D ;D ;D
Re: sumps for V6's
« Reply #10 on: 17 April 2008, 21:43:36 »
You use the same sealent as the oil cooler for the sump....i.e. the grey stuff in the mastic type tube
Smallfry
Re: sumps for V6's
« Reply #11 on: 17 April 2008, 22:52:37 »
If the FWD (Vectra?) sump you have is alloy and not damaged, I will swap you an Omega one................with the wide front end ?
Cav9_4
  • Sutton-In-Ashfield,Notts
  • 2003 Omega 2.6 Elite
Re: sumps for V6's
« Reply #12 on: 18 April 2008, 09:31:12 »
Hi Jay,would a sump from a 1997 2.5 be the same?,if so i got one you can have...Wayne
« Last Edit: 18 April 2008, 10:00:42 by cav9_4 »
Page created in 0.063 seconds with 16 queries.
