Author Topic: Sticking window  (Read 1928 times)
Dangerous Dan
  • Manchester
Sticking window
« on: 17 April 2008, 16:00:58 »
my drives door window gets about 3/4 the way down and then gets stuck, it's like it is getting blocked by something.
any common faults or solutions anyone knows of/
thanks
markrl
  • London
Re: Sticking window
« Reply #1 on: 17 April 2008, 16:42:43 »
I probably just needs lubricating. Remove the door car and plastic membrane and give everything a spray with WD40. On the window runners use a nylon lubricant so as not to damage the rubber (Holts to an electric window lubricant specifically for this job). Just make sure while you there that the window glass is correctly seated on its runner.
Re: Sticking window
« Reply #2 on: 17 April 2008, 22:15:34 »
Personally I would NOT use WD40 - a grossly overused product !! WD40 is a "water dispersent" NOT a lubricant, and the carrier solvent can cause havoc on many plastics, causing them to go to a soggy mess.
As a lubicant old fashioned "3-in-1" is far better, and for window runners I use a silicon spray .. available from many places (including maplins !!)
Just my 2.35 p's worth (inc VAT)  :)
« Last Edit: 17 April 2008, 22:16:33 by entwood »
markomega25
  • Morden, Surrey, A3 gateway
Re: Sticking window
« Reply #3 on: 18 April 2008, 01:58:47 »
I have just freed up my rear nearside window (it would autoretract on closing all the time). I used a can of W5 silicon lube - cost 99p from lidl's but has done the job. No dismantling at all I simply sprayed it over where the window and runners meets the felt frames etc - it took about ten or so full up and down movements to work the lube down the runners and it working properly. I have sprayed all the other window runners too just as a preventative measure.
I would be careful of removing the front door card and spraying inside etc if you have side airbags. These airbags are apparently controlled from a pressure sensor inside the front door - and as mentioned earlier the door is sealed with a membrane to prived pressure in a prang to set the bags off.
If you do take the membrane off you must make sure it seals properly when refitting. Just be careful eh!
shyboy
  • Southport, merseyside.
    • Mazda 6
Re: Sticking window
« Reply #4 on: 18 April 2008, 09:42:03 »
If it sounds like it's being obstructed by something solid, check the condition of the door strap mechanism. My 2.0l driver's door strap started to jam half way through opening and closing until it finally broke inside the door, but before it did so it fouled the window operating mechanism and I assume it in some way forced the arm out of its socket, so stopping the window from operating although the motor is still working. If the same thing has happened on yours, perhaps there's a simple obstruction fouling the window mechanism.
I still haven't got round to fixing mine by the way.  :-[
Marie
    • 2ltr LPG Estate
Re: Sticking window
« Reply #5 on: 18 April 2008, 10:00:12 »
Sounds like what shyboy and myself have had happened.
the dorr strap mechanisum fouls the window guide denting and buckling it. so even it you repair the door strp mech you will still have the same problem and need to replace the window guide.
i have just fixed all mine and now you would never know it had happened. :)
shyboy
    • Mazda 6
Re: Sticking window
« Reply #6 on: 18 April 2008, 11:22:43 »
Clever clogs!  ;) Did you have to do the reinforcement plate repair, Marie?
Marie
    • 2ltr LPG Estate
Re: Sticking window
« Reply #7 on: 18 April 2008, 11:32:22 »
Well i have explained it on this thread........
http://www.omegaowners.com/forum/YaBB.pl?num=1208254864
let me know if you dont understand what i have explained and ill see if i can put it into better words. :)
shyboy
    • Mazda 6
Re: Sticking window
« Reply #8 on: 18 April 2008, 13:08:50 »
Sorry, Marie. I hadn't caught up with your explanation in that thread.
Hope mine's as straightforward when I get round to doing it.
Bill.
Marie
    • 2ltr LPG Estate
Re: Sticking window
« Reply #9 on: 18 April 2008, 13:12:06 »
Bill.
PM me if you get any snags and ill send you my number and talk you through it.  :)
shyboy
    • Mazda 6
Re: Sticking window
« Reply #10 on: 18 April 2008, 19:32:02 »
Thanks. Will do.
