Author Topic: Fault code 16 & 19  (Read 1762 times)
cbs2
  • East Kilbride
  • Right....Fire Up The Quattro!!!
Fault code 16 & 19
« on: 18 April 2008, 22:40:25 »
Hiya guys
Up in inverness tonight so the rear brakes can get done tomorrow.
On the way up, the EML came on.
I pinned it & got 1-6(knock signal circuit 1) and 1-9 (Incorrect RPM Signal).
I know the 1-9 will show as the engine was off when I clipped it, but the 1-6, is it just a sensor replacement?
If so, anybody have a part number handy?
How difficult is it to change?
will a dealer have it in stock?
Thanks again guys( and gals)
Colin
Taking part in the 2010 sucata split charity banger run. www.sucatasplit.com
www.boozebrothers2010.co.uk
Ex-mig owner................For now
Re: Fault code 16 & 19
« Reply #1 on: 18 April 2008, 22:42:28 »
Hiya guys
Colin
a 19 is a fubar sensor (31 for not engine running ;))
16 - more likely cable, not sensor.  Check it, may be repairable.
« Reply #2 on: 18 April 2008, 22:43:03 »
i would check with the engine running and see if you still get 19.,if you do then change the crank sensor and the other code might disappear when the 19 does..........oops beaten to it ,(take his advice first,knows infinitely more than me) :)
« Last Edit: 18 April 2008, 22:44:43 by albitz »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 18 April 2008, 23:01:52 »
Hiya guys
Colin
Crank Sensors are £49.35 with TC bought one yesterday and take around 15 mins to do from start to finish. There is also a great How Too in the maintance section :y
cbs2
  • East Kilbride
« Reply #4 on: 18 April 2008, 23:06:54 »
Tried paperclip with the engine running.
Same results 1-6 & 1-9 shown.
Is that the crank sensor next to the oil filter? as i changed that a coupla months ago :-?
Where is the knock sensor located?
Any part numbers known before I hit the dealers in the morning?
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #5 on: 18 April 2008, 23:44:36 »
Yes the Crank Sensor goes next to the oil filter.. but did you keep the wire away from the exhaust like the How Too tells you too?
Did you fit a Genuine one the other week?
Where is the knock sensor? I know if you stand at the front of the car with the bonnet open, where the Aux Belt Tensioner is just above that you can see the cable tray running horizontal with a wire coming out of the tray plugging into another wire and they are both in a little fastening bracket if that makes an sense... well follow the wire from the plug it goes down by the alternator I think at the end of that you will find it. :y
« Reply #6 on: 19 April 2008, 16:24:37 »
19 is failing crank sensor. No ifs or buts. Make no difference if engine running.
