Author Topic: limp box !  (Read 1294 times)
limp box !
« on: 19 April 2008, 20:01:26 »
for a while now (about 6 months) when i floor the throttle to kick down my gearbox goes into limp mode.if i stop turn off ignition and then start off again every thing works fine ,until next time i floor it.any suggestions. :question
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: limp box !
« Reply #1 on: 19 April 2008, 20:09:33 »
Do a paper clip test, see Maintenance Guides, then report back.
I like red cars
Re: limp box !
« Reply #2 on: 19 April 2008, 21:03:48 »
done p/clip test,no codes.couldnt see anything directly relavant in maintenance guides.i was thinking it may be to do with the selector switch ? :-/
Mike Collins
  • North of Bristol
Re: limp box !
« Reply #3 on: 19 April 2008, 21:21:15 »
Fluid level and quality ok?
Marie
    • 2ltr LPG Estate
Re: limp box !
« Reply #4 on: 20 April 2008, 09:55:49 »
I would do a fluid level check asap, or change the oil which would be even better. will make the world of difference.
To top the box up you will need a ratchet and a 13mm socket.
ensure the car is level, if i jack the car( i dont tend to anymore as i am a skinny cow and can get under the car without it) i jack the car until its level (if not already). loosen the filler plug. right start your engine. i then run my box through the gears then place it back into park. after this once the car has ran for around 5/10 mins. take the filler plug out and start filling. i tend to use a 1ltr bottle with the spout on it, keep filling until the box starts over flowing then quickly replace the filler plug. tighten
jobs a gooden!
with a Trade Card the oil from VX works out at £3.80 per bottle.
Good luck
