Author Topic: Idle problem  (Read 1121 times)
RXC
Idle problem
« on: 19 April 2008, 16:21:46 »
Hi all
My 2.6 CDX (Y reg) has developed a fault with the idle. It revs at 1.8 rpm when it used to be approx. 1.0 rpm.  It used to occur on the odd occasion, but now it's always.  If I am at standstill, I roll the car forward in gear and the idle drops to normal tickover. The problem starts again every time I am at standstill.  A garage has looked into this problem, but cannot solve it.  Any ideas please.
Many thanks - rxc
FRE07962128
Re: Idle problem
« Reply #1 on: 19 April 2008, 16:24:48 »
Hi all
Many thanks - rxc
To me it sounds like a sticking throttle control somewhere if it is not an engine management problem.  WD40 may cure it if you can discover where it is sticking.  :D  Lizzie Zoom
Mike Collins
  • North of Bristol
Re: Idle problem
« Reply #2 on: 19 April 2008, 17:34:37 »
The throttle is a drive by wire system, no mechanical connection between pedal and butterflies.
I would suggest remove and clean the throttle body, unblock and clean the engine breather system.
Expect to find quite a mess around the butterflies.
There is guidance on here for breathers.
Idle should be 500/650 RPM depending on A/C running or not.
RXC
Re: Idle problem
« Reply #3 on: 20 April 2008, 11:12:06 »
Thanks for you replies, I will get on with the job and let you know the results.
rxc
