Author Topic: 2.6 timing belts  (Read 2581 times)
Jay w
  • Plymouth/Poole
  • omega gone
2.6 timing belts
« on: 22 April 2008, 14:11:35 »
I have just been told that there are 2 different timing belts, my engine number does not seem to help.
Can anyone advise me what the differences are between the two?
My engine is a 2002 2.6
TIA  :y
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: 2.6 timing belts
« Reply #1 on: 22 April 2008, 14:15:15 »
may or may not help....but the 2.6 vec i have had an issue with the backing plate as well - i believe there are two.
Doesnt answer your question but something to be aware of  :-/
ians
  • Reading
« Reply #2 on: 22 April 2008, 14:18:55 »
Engine number should do it.  Why was that a problem?
« Reply #3 on: 22 April 2008, 14:21:25 »
Is this down to whether the bottom idler is adjustable?
Have a look. I think the old (adjustable) setup is with the tensioner quite close to the crank pulley. On the later (non-adjustable) cars it is about 1/2 way along the belt run between the crank pulley and cam 4 sprocket, so higer and further over on the engine.
At the same time, the tensioner backplate changed to position the adjustable idler differently between the 2 banks. IIRC, it used to be central between the banks and it moved towards cam 3's sprocket, although I'm not 100% sure I've got that round the right way. :-/
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #4 on: 22 April 2008, 14:32:51 »
moine has a part number where the engine number is, it is a vaux recon lump that i have bought 2nd hand.
I was under the impression it was due to the bottom idler pulley but couldn't be sure
« Last Edit: 22 April 2008, 14:33:22 by jay_w »
« Reply #5 on: 22 April 2008, 14:38:04 »
The bottom idler pulley was positioned centrally from about 98 onwards, its the top mount that changed along with the bottom idler being non-adjustable. If the backing plate has a couple of small pegs in the back of it for location purposes then its the later version.
Dazzler
  • Haverhill, Suffolk
« Reply #6 on: 22 April 2008, 16:33:55 »
And if all else fails, as was my case i just put all the new rollers onto the old backplate as my kit was wrong :-/
ians
  • Reading
« Reply #7 on: 22 April 2008, 18:23:15 »
I would have thought that a 2.6 was bound to be the later type - they didn't make it for that long did they?
Taxi_Driver
« Reply #8 on: 22 April 2008, 18:32:21 »
2.5/2.6/3.0/3.2 08300419 to 08578511 p/n - 9201887
2.5/2.6/3.0/3.2 from 08578512 p/n - 93172354
So you can see there are two different kits  :y
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #9 on: 22 April 2008, 18:51:27 »
the dealer has both in stock so they are letting us have both and wil only invoice for the one we use
Dazzler
« Reply #10 on: 22 April 2008, 18:54:15 »
Can't say fairer than that Jay ;)
