Author Topic: Radiator leaking  (Read 3678 times)
Richie London
  • heathrow
Re: Radiator leaking
« Reply #15 on: 14 April 2008, 20:21:07 »
mine was leaking from the same spot, couldnt repair it so i got one from this site for 60 quid including delivery
looked nearly new too, used this before and never had a prob
http://www.1stchoice.co.uk/
richie
Dirk
  • Fife, Scotland
« Reply #16 on: 14 April 2008, 20:21:07 »
Thanks for all the replies so far.
That quick seel will that work on hard plastic you think?
Might be worth a visit in B&Q tomorrow or Halfords.
Always cheaper then a new radiator  if it works  :)
« Reply #17 on: 14 April 2008, 20:38:05 »
got 2 choices, either works or if doesn't ;)
Dirk
  • Fife, Scotland
« Reply #18 on: 14 April 2008, 20:50:36 »
I will let you know what the result is. :)
« Reply #19 on: 14 April 2008, 22:53:27 »
I've just had a look in the garage ( I was at work before) it's called Magic Bond
« Reply #20 on: 15 April 2008, 08:35:45 »
Got a spare good V6 radiator in the garage if your near Nottingham.
Dirk
  • Fife, Scotland
« Reply #21 on: 22 April 2008, 21:49:21 »
This weekend I cleaned the place where the leak is and used a compound glue but today it started to leak again.
I took out a soldering iron and whilst it was still leaking I melted the plastic a little bit , enough to stop the leak and then melted some plastic on it from some tie raps to give it a little bit more strenght and waited for half an hour.
I started the engine and let it run till the temperature was around 90 degrees and there is no leak visible.
So hopefully it is sorted bt will keep an eye on it for the next week.
