Author Topic: Radiator leaking  (Read 3679 times)
Dirk
  • Fife, Scotland
Radiator leaking
« on: 14 April 2008, 19:10:15 »
When I came home I discovered some water under the car and found out that it is on top of the radiator where the hose connects that goes to the engine.
It is a pin hole and it doesn't loose to much water but want to repair it or put a new radiator in asap.
Does a leak stopper help for these leaks or is it better to replace the whole radiator straight away?
If I go to a partco store or Halfords what will it cost me?
I have seen them on ebay for 106 Pounds but if I want to replace it this weekend then I probably need to pick it up from one of these stores.
At the moment for a quick fix I put some glue on top and some filler and tape and then 2 tieraps over it and it stopped to leak for now.
Re: Radiator leaking
« Reply #1 on: 14 April 2008, 19:21:28 »
Did it have a jubilee clip on it?
You'd have to ring round for prices and stock levels - nobody stocked a TD one when I wanted one :(
Dirk
  • Fife, Scotland
« Reply #2 on: 14 April 2008, 19:36:09 »
Yep clip is still on.
The hole is on the pipe where the hose connects to.
The hard plastic bit.
« Reply #3 on: 14 April 2008, 19:40:51 »
Jubilee clip or spring clip?
All ones I've seen with that tube damaged are due to jubilee clip - which is why I think Vx use a spring clip.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #4 on: 14 April 2008, 19:43:11 »
Could have sworn mine was aluminium :-?
Can you not bring the rubber hose further over to cover the hole and use a jubilee clip like Jamie said?
If the rad hose is ali you could get the hole welded up for say £20 :y
« Reply #5 on: 14 April 2008, 19:44:26 »
I hated those spring clips at first, but have realised that they give a nice even clamping force all round and can't be over tightened. ;)
« Reply #6 on: 14 April 2008, 19:46:42 »
I have seen them on ebay for 106 Pounds  ......
Mine cost around £200 on Trade Club from Vauxahll last year, V6 auto.
« Last Edit: 14 April 2008, 19:47:27 by Andy_B »
« Reply #7 on: 14 April 2008, 19:47:27 »
No, dont use jubilee clip, I'm thinking that may be route cause.
Dirk
  • Fife, Scotland
« Reply #8 on: 14 April 2008, 19:48:26 »
Unfortunately it is hard plastic and the hole is in the inner corner.
I was thinking of using a solder iron to close it that way but I think I will make this part only weaker.
If it was the hose itself then I would have replaced it already
« Reply #9 on: 14 April 2008, 19:50:20 »
Not sure if chemical metal could be used to plug it?
« Reply #10 on: 14 April 2008, 19:50:24 »
Only if you're ham fisted with 'em & tighten them as hard as possible. I had stainless Jubilees all round on mty Senator (even the dual ram) & never had any problems.
I do see your point though.
« Reply #11 on: 14 April 2008, 19:51:38 »
Its not so much overtightening, its the spring ones allow expansion/contraction with heat.
« Reply #12 on: 14 April 2008, 19:56:51 »
I've repaired a thermostat housing with J-B Weld before. It was an ali casting though, so it probably didin't flex as much as a plastic radiator. Maybe worth a try.
« Reply #13 on: 14 April 2008, 19:57:07 »
Not quite the same I know but ...... I sucessfully repaired fuel tank with something similar. Under water putty Something or other Bond I think. Came as a roll that you just cut a length off & kneaded it untill a uniform colour. It worked brilliantly
« Reply #14 on: 14 April 2008, 19:58:54 »
The stuff I use is called Qwiksteel or something like that. I think they all work same way, with similar capabilities :)
