Author Topic: Starting problems.  (Read 1453 times)
VX1
  • Reading, Berkshire
Starting problems.
« on: 21 April 2008, 18:55:06 »
I have a starting problem with the 2.2ltr diesel I have here. I have fitted the oil cooler to it and the thermostat and housing (thankyou to autovaux for supplying them) connected everything else that was taken off (Hoses extra) but now it wont start. It turns over no problem but does not fire, it seems if the fuel is not getting to the injectors.
Question, would this be anything to do with the bleed off pipe? or is it something else? I did connect jump leads to the battery and forgot that the ignition wa turned on, could I have blown the diesel pump fuse as it doesn't look as there is any fuel coming up. ( removed the bleed off pipe whilst the engine was bieng turned over)
Any help gratefuly received.
Paul  :y
P.S this is the car I have had here for nine months.
« Last Edit: 21 April 2008, 20:40:56 by vauxhallomega1 »
Vx Trade club card holder
Halfords trade card holder
Dazzler
  • Haverhill, Suffolk
Re: Starting problems.
« Reply #1 on: 21 April 2008, 20:03:09 »
Spounds like it might have an airlock in the fuel system, have you cracked an injector pipe to see if the fuel is getting there?
VX1
« Reply #2 on: 21 April 2008, 20:39:56 »
No I haven't. Could I have blown a fuse or relay for the diesel pump?
Paul
Dazzler
« Reply #3 on: 21 April 2008, 21:18:55 »
Its always possible and the easiest to check i would have thought.
VX1
« Reply #4 on: 21 April 2008, 21:33:13 »
I will check this tomorrow when I get home from work. I keep txting the guy but he is not returning the txt's and I need shot of the car for the space for when I pick up my caravan. Any suggestion's without being to harsh on him?
Paul  :y
VX1
« Reply #5 on: 23 April 2008, 09:35:27 »
Well got the car started last night. Took a few turns but managed to get it going. Hopefully he will be coming to get the car tonight so it will be gone for good.
Paul  :y
