Author Topic: headlights  (Read 1339 times)
opelsr
  • suffolk
headlights
« on: 26 April 2008, 21:17:18 »
Hi will the headlights  from a r reg cdx fit into a  p reg gls are they the same size
hotel21
  • The Kingdom of Fife
Re: headlights
« Reply #1 on: 26 April 2008, 21:33:38 »
All the headlamps across the range are the same physical size.
Electrical connectors are a different matter....
If changing from standard lamps to HID then theres a wee bit of rewiring required...
Check the howtoo's to see whats involved....
Taxi_Driver
Re: headlights
« Reply #2 on: 26 April 2008, 21:39:59 »
If the R reg cdx has HID's  :-/ I think its poss too old  :-/
Thats an understatement  ;D
I looked into it on mine........its a nightmare  ;D
Involves changing wiring looms  :'(
Hence why i went down the aftermarket HID kit
Tho i would advise not to fit those unless you have projector lights
« Last Edit: 26 April 2008, 21:42:06 by Taxi_Driver »
Steve1077
Re: headlights
« Reply #3 on: 27 April 2008, 15:34:06 »
Are the projector lights any better than the older type with normal bulbs? Or do they just look better?
