Author Topic: Alarm PITA - anyone know how to disable it?  (Read 7227 times)
« on: 24 April 2007, 09:59:02 »
Over the last couple of days my alarm has started going off pretty much every time I park up. It's fine for 30 minutes then it goes off.
Sounds like bonnet sensor, I know. I had a poke around last night in the dark and it seems intact but I will investigate this a little further.
The really odd thing is that it just went off in the office car park and the horn silenced when I unlocked the car but not the siren. This continued for another couple of minutes. In the end I got in the car, switched the ignition on, then off, then on again. Eventually after I'd left the ignition on and resorted to reading the handbook it stopped.
Crept out of the car and locked with a key and fingers crossed it's OK.
I didn't think the alarm was set unless the car was deadlocked by pressing the lock button twice? Pretty sure I locked it once today, mindful of the problem.
Does this sound like normal behaviour or is there a fault with the power sounder as well perhaps?
Was my silencing method correct? Can't think of anything else I should have done. (except to apply  Sammy Sledge to the power sounder >:( )
Cheers,
« Last Edit: 24 April 2007, 23:20:03 by Kevin_Wood »
Re: Alarm PITA
« Reply #1 on: 24 April 2007, 10:00:48 »
As a check, unplug the bonnet sensor and see if it stops it going off...
Re: Alarm PITA
« Reply #2 on: 24 April 2007, 10:44:01 »
OK. Will do. Was thinking about duck tape but that's even easier!
Is it normal for the power sounder to be a pain to silence?
It's 4 years old so possible the power sounder battery's ducked I guess.
Craig_R
  • Watford
Re: Alarm PITA
« Reply #3 on: 24 April 2007, 10:47:17 »
If I remember right Tunnie Just ended up ripping his Power Sounder Out or was it the Power Sounder Batts
Mine just stopped making the 4 beeps noise and i have nor heard a peep out of it since, cant say the same about my horn alarm lol damn thing has a mind of its own time i looked into it
Mod's
[To be Fitted]Reverse Sensors
Re: Alarm PITA
« Reply #4 on: 24 April 2007, 10:54:02 »
I'd never heard anything from mine until Sunday night when it went off. Certainly hasn't been giving the 4 peeps warning. I'll pull it out sometime and change the batteries, then take a decision on whether to put it back in or not! If the Horn doesn't put them off they'll get in anyway. Guess the power sounder just adds Thatcham approval.
Re: Alarm PITA
« Reply #5 on: 24 April 2007, 10:54:44 »
My horn alarm sounder has been disconected ::)
Craig_R
  • Watford
Re: Alarm PITA
« Reply #6 on: 24 April 2007, 10:58:50 »
I think the Batts for the power sounder are hard to come by these days as the company who made them does not anymore if my memory serves me right.
Mod's
Re: Alarm PITA
« Reply #7 on: 24 April 2007, 12:01:39 »
I'm sure I can bodge something.  :y
May just be the bonnet switch though as MarkDTM suggests.
STMO123
Re: Alarm PITA
« Reply #8 on: 24 April 2007, 13:20:33 »
My alarm used to fart around all the time. I just reached in and disconnected the power sounder. Good as gold since. :y
Re: Alarm PITA
« Reply #9 on: 24 April 2007, 16:32:55 »
Yes i ripped my backup alarm module out  ::)
Kept going beep beep beep after getting out, then it started going off randomly too.
Was interesting removing it, i must have upset it cause it started going off, but when i pulled out the cable it was. beep beep beeee[size=10]eeeeeee[/size][size=9]eeeee[/size][size=8]p[/size]
My dads alarm kept going off, took it to the dealer a number of times (before OOF) and they greased up the bonnet switch and so on. But it was the backup module.
My money is on the backup alarm module being goosed.
Re: Alarm PITA
« Reply #10 on: 24 April 2007, 22:29:41 »
OK. This has now become a major hassle. Got home an hour ago and it has gone off twice. I'm likely to become (even more) unpopular in this neighbourhood if I can't stop the damned thing. Tried unplugging the bonnet switch the first time to no avail. Had a look inside it and it's clean, appears to be operating normally. Might need adjustment, of course, but in any case the alarm goes off with it disconnected.
Is there any way of locking the car without setting the alarm?
Is there a way to disable the alarm (fuse I can remove, etc?)
Not got my Haynes manual to hand so no wiring diagrams.
Answers on a PM if you like as this is potentially a bit sensitive.
Taxi_Driver
Re: Alarm PITA - anyone know how to disable it?
« Reply #11 on: 25 April 2007, 06:26:29 »
Try pressing the button with the man running away after you turn off......this will turn off the internal movement sensors...and if it stops the false alarms will tell you where the fault lies  :y
STMO123
« Reply #12 on: 25 April 2007, 07:20:11 »
If you want to lock the car without setting the alarm, simply reach in through the rear drivers side door, press the door button on the drivers door down,( this should lock all four doors) and then close the rear door.
I will post later on how to disconnect the power sounder (very simple)
« Last Edit: 25 April 2007, 07:21:00 by STMO123 »
« Reply #13 on: 25 April 2007, 07:53:33 »
If you want to lock the car without setting the alarm, simply reach in through the rear drivers side door, ........
.... making sure of course that your keys are in your hand/pocket!  :o
« Reply #14 on: 25 April 2007, 09:31:06 »
Thanks for the suggestions.
I locked it using the "reaching in through the rear door" trick.
I think I may have found something, although I'm not convinced it's the source of my problems. The boot light pin switch was loose on its' mounting screw so I've cleaned that up, mounted it properly and also added a little self adhesive felt pad where it contacts the body. I was moving stuff in and out of the boot on Sunday so maybe I dislodged it. Still don't have a lot of confidence that it's the issue but time will tell.
Cheers,
