Author Topic: Clock illumination bulbs blown  (Read 1645 times)
Bacon Butty Man
  • Cleveleys Nr Blackpool
  • now own a Laguna 2
« on: 29 April 2008, 14:01:44 »
have looked at the removal of the clocks thread and looks pretty straight forward, but when all the screws are out will the clocks simply lift out and what kind of roome is there to get at the buld, are there any linkages i would need to remove. :-/
my Rover 75 Club SE
markey mark
  • SLady bitshorpe north lincs
Re: Clock illumination bulbs blown
« Reply #1 on: 29 April 2008, 14:02:33 »
just a plug to mid mick ! :y
FRE07962128
« Reply #2 on: 29 April 2008, 14:23:45 »
I found that the clearance between the clocks/mid housing, the upper lip of the dashboard and the top edge of the steering column was very limited, even after removing the top cover of the said column.
However, with some wriggling and angling of the clocks unit it all came to replace the bulbs.  Just be careful of all the circuitaryon the back as  it could be easily damaged. :y
Bacon Butty Man
« Reply #3 on: 29 April 2008, 14:37:18 »
the clocks dont seem to lift straight out, is the a way theuy pull out
my Rover 75 Club SE
FRE07962128
« Reply #4 on: 29 April 2008, 14:48:55 »
No they do not lift straight out :'(; as I stated you have to wriggle the whole unit into an angle where you find it all does come out. :y
Bacon Butty Man
« Reply #5 on: 30 April 2008, 14:21:56 »
woohoo, i can see how fast i am going now,  :y :y :y :y :y :y :y
my Rover 75 Club SE
