Author Topic: Petrol gauge false reading  (Read 1038 times)
Machinmacone
  • Sheffield
« on: 03 May 2008, 13:05:39 »
Hi all
         2.0 L 0mega petrol gauge has been faulty a while now When it's showing nearly half full it runs out any ideas anyone.
                             Cheers Julian.
Re: Petrol gauge false reading
« Reply #1 on: 03 May 2008, 13:32:51 »
Hi all
                             Cheers Julian.
Its worth popping the fuel pump assembly out of the tank (not hard to do) and checking the float on the level sender is free to move and not fouling on any of the pickup pipes.
Machinmacone
  • Sheffield
« Reply #2 on: 03 May 2008, 14:29:31 »
Hi all
         Thanks for the response Mark does anyone know where i can get a fuel pump cover plate as on inspection mine is all corroded.
                                Cheers Julian.
« Reply #3 on: 03 May 2008, 15:24:27 »
Fuel senders I've come across in the past have just one 'earth' to it. If you ground this you should read 'FULL' on the gauge. A lot easier to do as a first test than remove the float/sender unit. If you don't get a full deflection then it's your gauge that's fubar'd.
« Reply #4 on: 03 May 2008, 15:27:29 »
Hi all
                                Cheers Julian.
Clean it up and slap some grease on it to stop it getting any worse....
